2007 Chevrolet Equinox LS New Cars Logo
Jim Kanniard Posted on Apr 11, 2014
Code p1682 driver 5 line 2 - 2007 Chevrolet Equinox LS New Cars
  • Tom Chichester Apr 11, 2014
    Hi Jim Kanniard, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? No such code listed. Could it be some other code?
  • Troy Beardslee
    Troy Beardslee Apr 22, 2019
    Coral crank over but will not start for like three hours
lewis pichardo
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 01, 2015
lewis pichardo
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5131
Points
Mi chevy equinox 2007 esta con un grave problema en el encendido, cuando arranca, lo hace deficientemente y la pantalla dice que hay perdida de potencia, conecte un OBD II y me da el codigo P1682 driver 5 line 2...quisiera saber que significa y como puedo resolverlo,ya que es muy desagradable lo que estoy pasando
2007 3.5l V6. Why does it show codes for no connection to the TCM u0101 and a code for driver 5 line 2 p1682 and an error light turns on?
the p1682 for pontiac is an ignition problem https://www.700r4transmissionhq.com/pontiac-g6/ as to the u0101 that can be related this code can pop up with a low voltage problem to tcm failure https://repairpal.com/obd-ii-code-u0101-lost-communication-with-tcm
2009 Chevy Impala Code P1682
P1682 Chevrolet Description There are 2 ignition 1 voltage circuits supplied to the Engine Control Module (ECM). The first ignition circuit is provided by the powertrain relay, through a fuse. This ignition 1 voltage circuit supplies power to all the internal ECM circuits associated with the throttle actuator control (TAC) operation. The second ignition 1 voltage circuit is supplied by the run/crank relay through a fuse, and is used to power the remaining internal ECM circuits. If the ECM detects a voltage difference between the 2 ignition 1 voltage circuits, DTC P1682 will set.
Read more: https://www.autocodes.com/p1682_chevrolet.html
2answers
2007 Chevy Trailblazer SS 6.0 Ltr Engine OBD2 Code P1682
I did some testing, fuel pump was bad but not the problem. Turns out I had a bad power train relay. I jumped it and it fired right up and ran at idle smother than it has in a long time
My 2007 GMC envoy Denali after it has been running for a few minutes the engine dies either sitting there or while driving, the engine will turn over but will not fire. P1682 code is confirmed
There are 2 ignition 1 voltage circuits supplied to the engine control module (ECM). The first ignition circuit is
voltage circuit is supplied by the ignition switch through a fuse, and is used to power the remaining internal
will set.
Get a subscription to alldatadiy.com and print out the troubleshooting steps. You've already wasted more than the cost of a good manual by replacing a good switch.
Chevy code P1682?
P1682 Chevrolet - Ignition 1 Switch Circuit 2
Possible causes
- Faulty ignition switch
- Ignition Switch harness is open or shorted
- Ignition Switch circuit poor electrical connection
- Faulty Engine Control Module (ECM)
What does this mean? What does this mean?
When is the code detected?
The ECM has detected a voltage deifference between two circuits
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Possible no crank or start
Read more: http://engine-codes.com/p1682_chevrolet.html#ixzz3dr4CYBUT
Am having trouble with my chevolet colorado 3.7 lt
Possible causes
help.jpg What does this mean?
Possible symptoms
Read more: http://engine-codes.com/p1682_chevrolet.html#ixzz3Djm8K11C
Diagnostic code p1682
Code p1682-A/T FI signal A high output.
It's a C code fault.
I recommend you clear it.
4helpful
4answers
1998 jeep cherokee sport- i get a code p1682.
P1682 - Charging system voltage to low.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
