Trying to add remote extensions for some of my coworkers, how can i do it ? I also have a couple phones running directly off other phones. when an outside call comes in that phone that is running off the other one doesnt ring, why?
Hello Luis what model of phone system are you using?. Is it an IP-PBX system? What exatly do you mean by "I also have a couple phones running directly off other phones" and ."when an outside call comes in that phone that is running off the other one doesnt ring".We could be of help
Testimonial: "it is running off a KX-TDA100 yes a pbx. The ringing problem i figured out by programing the ICD Group straight to the pbx console. Think its a parallel line? Now he only thing im trying to figure out is how to add a Remote Extension to some of my coworkers Cell phones, cant find any info on Remote Extensions!? Please Help!"
Do the remote/mobile workers have extensions in the office and you want the mobile and the extension to ring at the same time or you want to assign independent extensions to the remote workers?
Set it up under program 4.1.3, i.e 14.Extension >> 1.Wired Extension >> 3.Speed Dial
They have an extension at the office but want to add a remote extension to transfer to their Cell phone when they are not in the office.
Forward if not answered to cellphone
See the attached guidance, hope it helps.
SOURCE: Panasonic Kx-T123230 extension to ring
hope this help...
with a handset on hook...press PROGRAM and press 3 (number 3 button) this should give you a choice of which extention you want the phone to ring.. ie 1or 2 or three... Then finally press STORE
SOURCE: I cannot change the time on my phone
from reception phone with phone on hook dial star star 1234
then dial ooo this brings you to the date and time menu
SOURCE: PANASONIC KX-TDA-50 PHONE SYSTEM WITH
From the main phone, press PROG **1234 and dial 004. Press ENTER 2 times (watch out, it moves on the display) and you will be looking at 101 : OPERATOR if it's still unprogrammed. Keep pressing NEXT until you get to the one you want to change and use a combination of the keypad and the AUTO ANS button to spell out the new name. The STORE button saves it, the right arrow and clear button step back and forth on the line you're entering.
You can pick up the handset and drop it back into the cradle when you're done to exit.
Carl
SOURCE: changing the names fixed to internal extension numbers
If you can not log into the programing tool to change it that way then you will still need the Installer password. However from the main ext typically the first ext or 101
hit the Program soft key just below the LCD
push * then #
password
004
ext number you wish to change
type in new name
ENTER
END
SOURCE: I need to change an extension name on our
If you are using this phone with a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
