SOURCE: Panasonic KX=T7433 VTR Button
get to www.panasonic.com and click in the support and dwonload section then type ur model number and sart download the manuals for free and a lot more!
SOURCE: Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
SOURCE: KX-T7433 - message light does not work
Assuming that the 74xx phone is connected to a Panasonic TD system, the only code is dialing 701 on the intercom, or pressing the MESSAGE button and dialing the 3 digit extension. You can't set your own MW, so you need to do it from another phone to your extension to test it. It also has to be the hardware number ie 101-116 or 132 and not Phantom numbers.
Your 74xx phone could be connected to a TDA or the numbering plan may have been changed, but those are obscure situations.
Carl
SOURCE: panasonic kx-t7730
Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
PLEASE vote if this was helpful
SOURCE: How do I change the time on my Panasonic phone
The Panasonic TD phone system has been manufacturer discontinued for at least SEVEN years. In all that time, you never learned how to program the time?
From the book. Go to the Manager or operator phone. Press PROGRAM **1234 and dial 000.
It will let you use the FWD button to step through the date and time. Key in the numbers and press STORE.
Pick up and drop the handset back in the cradle to exit programming.
Carl
