May i get the spares from their shown room at vadapalani or elsewhere
SOURCE: Noisy LG Fridge Freezer
most likely the evaporator fan is hitting some ice that has formed on the mounting shroud. You will have to defrost the unit by leaving it off over night. Also what contributes to this broblem is the location of the temp sensors. they should be checked that they are in the holders for them and not buried into the foam insulation. There is on in the ref on the top of the liner and one in the freezer. These pop off. remove them from the foam and insert them into the holders. If you can't do this then it may be wise to use a service person to do check it.
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
SOURCE: LG GR-349R bottom mount freezer gets heavy ice
Find the drain tube in the back and check it for a frozen state. If it si,use a hair dryer to thaw it. If it does it again, you have a defrost problem
SOURCE: my top freezer isn't working properly i thought it
its most likely to be the thermostat in the freezer packed up on you and the only real way to test this out is to fit a new one,
SOURCE: Double door fridge model no.Gr 409gl, when the
Please check the model number again. The number you gave comes back as a oven. Please look on the inside of the door to see if is posted there or elsewhere on the unit.
Whirlpool ET1FHTXMQ01 parts manual.pdf
You can also find a Tech Sheet wiring diagram=> Here
Thanks, Sea Breeze
