I have tried both batteries with the same result. The green charger light comes on OK but the red light comes on for a second or two the goes out. Both batteries do the same although the red light stays on longer with one battery than the other, about five seconds for one and fifteen seconds the other. Any help will be greatly apprieciated.
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
SOURCE: 14.4V Drill Battery Will not Charge
The battery is 14.4 volts so the charger should be 14.4 volts.
SOURCE: have 24v sds drill older type the one with the
not sure on the charge well have to check out but contact a interstate battery shop thy can rebuild most batteries
SOURCE: battery charger doesn't charge. light blinking
Plug in the charger and then being careful to only touch one contact with one lead use an ohm/voltage meter to check the voltage and see if the charger is putting out any voltage.
SOURCE: Charger light flashes with no battery charging. I
The charger is damaged. Return it to the place of purchase and demand a refund or replacement. If you paid by credit card call the credit card company and cancel that transaction.
SOURCE: My battery will not charge. ( Ryobi 18.0v)
Bothights on indicates a problem with the battery. You cam try cleanibg the battery terminal with a Q-tip moistened with alcohol. Allow it to dry completly before tryin to recharge. If that doesn't work the battery may be defective or broken. If it was dropped that could cause the damage.
