Lexmark T642 Laser Printer Logo
A
Anonymous Posted on Apr 10, 2014
950.10 vram mismatch - Lexmark T642 Laser Printer
Xerox 7435 machin error 041340 plz advice for solutions
I found a reference to this for you in a Xerox service forum from one of the forum admins, who said:".....try reseating the Transfer Unit and see if that will clear the code. If not please consider contacting your support centre for further assistance."
You can find the message in her forum complete with links on how to do the above at the link below. Good luck! --Mark
http://forum.support.xerox.com/t5/Hardware/6280-gives-error-041-340-MCU-VRAM-error/td-p/22376
6280 gives error 041 340 MCU VRAM error
Why would I not be able to listen to music. starting 1 jan. i get the Pandora page but the artist does not and music
Minimum Specifications to Run Pandora
Most modern computers will play Pandora just fine, without any modification.
Minimum browser requirements:
Internet Explorer 7
Safari 4
Firefox 4
Chrome 7
Minimum hardware requirements:
PC desktop: Intel Pentium 4 2.33 Ghz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM, or
AMD Athlon 64 2800 or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
PC laptop: Intel Atom 1.6 GHz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
Mac laptop: Intel Core Duo 1.5 GHz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
Mac desktop: PowerPC G5 1.8 GHz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
Minimum internet requirements:
Consistent bandwidth of at least 150 kbps
If you upgraded to Pandora One and want to use High Quality audio, we recommend having at least 300 kbps of bandwidth.
If you're not sure of the speed of your internet connection, you can test your connection speed at any of these sites:
http://www.speedtest.net
http://www.dslreports.com/stest
Cookies Turned Off
1helpful
N1996 ver
You can't. At least without taking it back to Apple and having it upgraded. The VRAM is "Video RAM" this is hardware and Apple are notorious about making things difficult to upgrade for consumers.
E-machine em350 bios vram
Sometimes you can increase the Shared Memory in the BIOS setup. I'm not sure if you have that setting or access to that setting, depends on the Motherboard. Use extreme caution when altering ANY settings in the BIOS. One worng step, and you have a new paperweight, not a Laptop. Take a look at eMachine Support : http://support.gateway.com/us/en/emac/default.aspx
How do i use maximum ram on my GA H55N USB3 MOTHER BOARD?
you are confused about old mobo and old Intel H55 chipsets
this PC has a iGPU chip aka. onboard GPU.integrated.
and is VGA port on MOBO
and this intel chip lacks any VRAM at all, and intel data sheet told you that it
steals (yes that word) DDR RAM to form and create, VRAM
so DDR RAM is 1.8GB (clear as day told you that , RTM)
there are 2 cures, more DDR ram
of use GPU card with say 1GB of VRam on the GPU card.
ram most be installed in matched sets. you failed that.
same sku # intel said and you ignored them the MMC maker.
DDR ram is not like light bulbs there are ton rules
max ram rule1. cpu sets the rule .
max per slot. there is only 2 slots.
min per slot
density rules not violated or rank and chip per side.
and matched sets.
or buy certified DDR in matched sets and end all this pain
DDR3 1666 (O.C.)/1333/1066/800 MHz
1.5V DDR3 DIMM sockets supporting up to 8 GB of system memory
Bios must like the DDR3 too or fail you will
windows 32 bit limits to 4GB minus Vram theft or 3.2GB (approx
the answer is buying the wrong RAM
but not one word what ram you really bought.
2+2=4GB or ram and must be matched, same SKU , intel say matched sku or can fail easy.
the made the mmc, so ignoring them is not wise.
the BIOS must like it too, newer ram super high density can fail.
1helpful
I want to download a 128MB Vram for my system. My problem is that I don't have any webite to get it for free from. Can u get it for me?
VRAM is special-purpose memory used by video adapters. Unlike conventional
RAM, VRAM can be accessed by two different devices simultaneously. This
enables the RAMDAC to access the VRAM for screen updates at the same time
that the video processor provides new data. VRAM yields better graphics
performance but is more expensive than normal RAM.. "from webopedia".
so yes VRAM will get you better video performance. Basically it has its own
RAM, not sharing from your system RAM.
Try here:
http://www.dl4all.com/tqh/tag/vram+128mb+5.html
or here
http://www.freshwap.net/forums/games/2553967-video-card-128-mb-vram-nvidia-geforce-fx-5600-ati-radeon-9500-a.html
Wel originally my operating system was vista having vram 128mb but when i installed a windows 7 then vram decreased into 64mb.now i can't run pes2010..please help me .. and one thing i checked in bios...
This sounds like you need an updated driver for your graphics chip set.
Try going to the support page for the type of laptop you are using and you should be able to find all of the updated drivers that work for win7.
2helpful
Vram corrupt I have had several Panic attacks lately, so ran Tech tool and it says my VRAM is corrupt. What is the best way to correct his problem. I tried zapping the PRAM but it did not help. I...
You should be able to resolve this by restting your SMC and THEN resetting your PRAM. First:
http://support.apple.com/kb/HT3964
...and then:
http://support.apple.com/kb/ht1379
General Info Needed
Google and more google
2answers
RED VERTICAL LINES ON SCREEN; SOME RUN IN BELTS ABOUT 1 INCH WIDE
Check if your gfx card isn't overheating. Be careful not to burn it out if this is the case. If it is not overheating try to update the graphic drivers.
Cheers
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
