Can't set it to play my ps2 from the TV or remote
SOURCE: Remote randomly works. 27" Symphonic TV... but remote works on other Symphonics in the house
I have the same TV & problem.
The problem is Not with the remote but with the remote receiving circuit in the TV. The remote works once in a while.
Anyone have the TV schematic diagram?
SOURCE: I own a symphonic 27" television
I had this problem on a symphonic 27 inch TV I just bought from a friend
who no longer had a remote. The thing with the menu and buttons on the
front of the TV doesn't actually change the TV to true game mode. I
don't know what it acutally does, but it isn't really in game mode.
When it is in true "game mode" you can't change the channels until you turn game mode off. What I did was bought a universal remote (a specific one that someone
told me about) for 8 bucks at walmart and I was then able to switch to
game mode with the Input select on the remote. The remote I bought that
actually worked is this one: http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=acc_glance_ce_ai_-2_1_tit/002-3174824-8273629
Make
sure you look at it before you buy it and make sure it has a button
that specifically says "input" on it. I know that some of the universal
remotes don't have an input select button or one that doesn't work. As
long as you get a Philips-Magnavox that has that button, you should be
ok. Much better solution that paying 30 bucks for a new remote
specifically for the TV. Hope this helps.
SOURCE: How do i get my symphonic tv into video mode without remote?
Hi Guys
This will help you a looooot
http://www.universal-remote.net/philipsmagnavox.html
SOURCE: Unable to program my Time Warner Cable remote to Symphonic TV
the instructions are on the back of the remote. if lost. you have to:
1) Turn tv on ( i would suggest turning it off then on)
2) Press the Device you want to sync (tv)
3) Press and hold the setup button it will blink once...let it blink twice before you go to the next step.
4) press 9-9-1
5) press the power key on the remote
6) press the channel up (CH +) button repeatedly until the device (tv) turns off.
7) when it cuts off immedieately press the setup button.
Press the "On" button on the symphonic TV to turn that set on.
2.
Hold down the TV button on the symphonic remote until all of the buttons on that remote flash.
3.
Type in 0053 code for the symphonic TV remote as you point the remote toward the TV.
4.
Press either the "Power" or "Pound" ("#") button on the symphonic remote to save the code
