Symphonic WF803 DVD Player/VCR Logo
A
Anonymous Posted on Apr 10, 2014
Factory reset need factory reset
2answers
Factory reset my motorola xpr 7550
It is written in it`s mannual you can find it in attached link Motorola MOTOTRBO XPR 7550 User Manual or here is the video tutorial as well which is not for the same model but could may helps you
My computer will not connect to my wndr3800 router but my computer will connect to my neighbors router
The first thing that you need to do is to reset the router. The reason why you need to reset the router because that will help you to fix the problem and to know the main problem/issue.
Steps
To perform a factory reset:
  1. On the back of your router, locate the Restore Factory Settings or Reset button.
  2. Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
  3. Release the Restore Factory Settings or Reset button and wait for your router to reboot.
    After your router is finished with the factory reset, the Power light stops blinking and lights solid green.
    Note: The Power light on newer router models lights solid white.
    The factory default settings are restored.
  4. or you can visit youtube for the video https://www.youtube.com/watch?v=nUOcjDy02ts.
Note: Once you reset the router it will be back to factory default settings and you need to setup the internet connection settings on to your router
Once your done with the hard reset try connect your computer and if your computer will have the same issue connecting to the router it only means that the problem is on your computer / try to connect other device first before you reset the router
1helpful
Factory reset
Factory reset Proscan PLT 70330 use power and volume buttons to reset.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Factory Reset on Proscan PLT7223G or Tablet
How to reset proscan tablet model PLT7033D to factory setting its locked
want to reset my PIN on my Proscan PLT7033D
Mar 23, 2016 • Cell Phones
How to do a reset for irulu 9 inch tablet?
In order to factory reset your device you will simply need to perform the following steps directly in order to reset your device.
1. Turn your device off
2. Press and hold the volume up button
3. Press and hold the power button
4. Release these buttons
5. Use the volume up and down keys to highlight the factory reset option
6. Press the power button in order to select the option to factory reset your device
Factory reset
Bro You Don't Need To Restore Factory Your Computer Just Renew Your Windows
It Will Automatically Reset The Factory Setting
How to factory reset d-link dir-825
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Router name was reset without my asking. i need to set it back.
how was the name reset and by who??????
if you mean you have to reset your router to the factory default settings
(note all settings will be lost you will need to reconfigure the router)
you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, depending on your router) to reconfigure your router settings or if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
3helpful
Hi i need to reset my rvx 1000 to factory
Page 42 or 69:
"To reset all of the parameters to the factory-set values
Use "9 PARAM.INI" on the SET MENU to reset all of the parameter values of all DSP programs within the selected group to the factory-set values (see page 42)..."
16helpful
Reset to factory specs for blackberry curve 8330
how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
To reset the phone back to factory state:
Go to Options -> Security Options -> General Settings
Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
Thanks.
Top Symphonic Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
