sabbath == When in Sabbath Mode, your oven will disable its automatic shut-off function to stay on longer than 12 hours. This means that the oven will stay in a Bake mode until shut off, which will allow you to use the oven for cooking or warming food.
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Time Setting Instructions:First press and hold ST/STP for a few seconds and make sure it says (Time 1). This watch has a (Time 2) to use in other time zones.You change from Time 1 and Time 2 by pushing the ST/STP button for a few seconds.Time 1 setting:- Press and hold the SET button (Light Function will blink) use the ST/STP button to select on or off. Then push the Mode button to go to the next function.- The Chime function will blink. Use the ST/STP button to select on or off and then push the Mode button to go to the next function.- Next will be to select 12hour or 24hour time by using the ST/STP button then press the Mode button to set the Hour, Minutes, and Seconds.- Continue to set the year but when you get to the Month/Day you have the option of putting the day first then the month, use the ST/STP to select then push the Mode button to enter the month and day.- When satisfied with your settings push the SET button and your done. Time 2 Setting:- Press and hold the ST/STP button it will say Time 2 and then go away only showing the time and date for Time 2- To adjust this time to another time zone you push and hold the SET button.- Use the ST/STP button and the RESET button to move ahead or behind in hours depending on time zone. Push the SET button when done.-Your time 2 is set for a different time zone and your Time 1 is set for your local time. Remember to use the ST/STP button to go back and forth from Time 1 to Time 2.
Hello,the F5 beeping is all about the Push button stuck. Check for the binding of Push button and control panel glass.If OK,replace the touch panel. Thanks
if you have a clock where the hands go around and smaller start and stop clocks, here's what to do. set the clock to current time, push in the stop button and turn it until it stays in, then push in the start button and turn it until it pops out. try this.
9.
The time of day does not display on my electronic oven control. If I
push the CLOCK pad on the control panel the time will display for a few
seconds and then it goes blank again.
On many ranges with electronic controls the time
of day display can by turned off or on by holding the CLOCK keypad down
for 15 seconds. Push and hold the CLOCK keypad. The time will
appear for a few seconds, and then disappear and finally it will
reappear and beep. Release the keypad and the time should continue to
display. Follow this same procedure to turn the time display off.
