usually to restore you have to use the same program u used for to make the back-up file ...or ..if it is a recovery file ..just insert the memory unit you have it on ..and click on the executable ...(in normal conditions it should open itself with the software used for to make it in the first place ... If the resetting cause the program to disappear..just reinstall that program first ..and use the recover feature from the program ...to access the back -up file ..
Slow performance can be from many different problems. The keyboard may be fine but the PC may have a problem. Except for a wireless keyboard which may have a low battery or obstructed receiver problem.
First go to START / Programs / System Tools / System Restore. Select SET RESTORE POINT and give it a name. This will let you restore your system to the current condition if anything goes wrong.
Try downloading "CCleaner" from www.download.com (it's FREE). Install it and let it clean up your Windows and your Registry. (You might de-select Cookies option to preserve your logins saved on your Internet browser) It will offer to save original Registry before cleaning it up. In most cases this will resolve slow performance from outdated Windows instructions and Registry errors.
Next go to My Computer / Right click on C drive (boot drive) and select Properties. Go to Tools and select Defrag Drive. If problem is serious you should also run Check Disk and select to make automatic repairs. These programs will take some time to run.
If the problem still persists, update and run your Anti-Virus software. If you do not have Anti-Virus software go to www.download.com and select AVG Free from the right hand column. This is a very good Free Anti-Virus software.
Disclaimer: The programs I recommend are suggested because they are free and very easy for the computer novice to use. I have no financial interest in these programs. I recommend and use these programs in my computer repair business.
i assume that you do not have physical restore disk? you did not re-format original hdd? os is vista?
to restore using embodied lg recovery centre:
press f11 during boot-up and execute "lg recovery centre"
this will actually erase all your settings, data and restore original windows vista on the machine.
this site should give you very detailed information how to restore your laptop to original condition, includes all manuals, first make notes of all conceivable details on the back label on your laptop:
Sounds like some kind of infection. Are you able to access other things like registry editor, folder options and task manager. Also let me what you have already tried to resolve this issue.
hello: look first in the systeem section and the hardware section if driver correct installed if yes take like msn messenger go in thd program to the options and you can checq sound and webcam or take skype in the options menu you can also checq the sound and webcam or if you have instal the driver and software from hp you wil also have capture program there you can also see trou the lens of the cam dont be scarry it are a picturre of you thad you wil see HI HI HI if in the systeem setting of hard ware you no see the section with the cam you must first instal the software you can download it from the hp site good luck
viruses often plant themselves firmly in the system restore files. They could also be preventing you from executing it. If you have "rogue programs" a system restore almost never works. You need to either clean the rogue programs in safe mode or backup your files and reinstall from scratch.
