Happens after printing Lots of gunk underneath the cartridges
SOURCE: grinding noise on startup
Problem
The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise.
Solution
1. Lift the top cover to the printer.
2. Turn the printer off and then on again.
3. Unplug the power cable from the back of the printer when the grinding noise starts.
4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
5. Take out the cartridges and close the top cover. Turn the printer back on!
6. Reconnect the power cord.
7. Open the top cover, reinstall the cartridges, and then close the top cover
SOURCE: Install cartridge
I did a master reset and now it will print but the ink level for the yellow cartridge still shows "empty" even though it is a new one but at least it prints for now anyway.
Master Reset:
Turn off printer and unplug.
Hold down "OK" button and "Help" button and plug in at the same time.
Turn on printer and wait for reset to finish.
It worked for me. Hope it works for everyone.
SOURCE: won't print after changing print cartridge, check printer cartridge light comes on!
please install the printer hp 1200 series
SOURCE: HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
