Here are two things to try: I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Depending on why your tablet is frozen, pressing the "Power" button -- sometimes called the "Sleep/Wake" button -- might turn it off. Some tablets give you the option to restart or shut down; if you have this choice, pick the option to shut down the tablet completely. If pressing the button once doesn't do the trick, hold it down for 15 to 20 seconds -- this often forces the tablet into shut-down mode.
Have you held the reset botton till it shuts of and when comes back on let go. If that don't do it plug it in to pc and reset it like that, or run an update.
Check the tutorial at Techniques to Tackle Android Tablet from Boot Stuck . One or two of these methods will wipe your data and your applications. Losing applications isn't so bad -- you can just reinstall them. But I hope you have backed up your data!
If your tablet is frozen what until the battery gives out.
Once it gives out charge it and turn it on if that doesn't work try this.
Get something small like a pin somewhere on your tablet there should be a little circle and the words RESET stick the little object in there hold it for five seconds and let it go your tablet will restart and reset. If that doesn't work your tablet is defected you need to take it back to the store you got it from
I saw (as I was trying to get a mates tablet going) in Security--Interface security seven items that you may need to unlock to access different things. They included Lan, Wireless, HD Audio, USB interface ect., just a thought. Tap on each and unlock if they are locked. First time I have looked at the tablet and was operating on common sense with not computer skills. Good luck
So you need to be In the main menu interface then press the power button for about 5 seconds to shut it down. Below is the power section out of the manual.
1.2 POWER
startup: Long Press and hold the power button, the system will enter the main interface
shutdown: In the main menu interface, Press the power button about 5 second to shutdown, The system can hint "power off" option, Clike"ok". you can safely shut down.
Lock screen: Short press Power button to lock screen or unlock screen.
Remark 1.When power is empty,system will shut down automatically.
2.Illegal turn off the device,restart will scan and restore the disk,it may take longer time to enter into system
Telnet is an application layer protocol. If you can telnet to the other router, then you do not have any network issues. However, the fact that you can telnet but not ping suggests that icmp messages have been blocked in the configuration of one or both routers. This is a security feature, because attacks can be launched via icmp messages.
