Question about Joyoung Automatic Household DJ12B-A603DG Dry Beans No-Net Soy Milk Maker
Machie does not work on second batch
After finished the 1st batch ,on the 2nd batch the machine stuck grinding at the 1st step.
My '03 VW Jetta GLS 1.8T Manual Trans grinds when shifting into second gear?
the synchros are not DIY, when they start to go it will grind when the RPMs are higher like getting on a highway, you can try double clutching and see if that helps.
Oct 01, 2012 | Cars & Trucks
1996 Kawasaki VN 1500 Vulcan Classic grinding in 2nd gear
Hi, Darryl for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
grinds into second gear Kawasaki Vulcan Forum Vulcan Forums http://www.kawasakimotorcycle.org/forum/kawasaki-cruisers/85623-2nd-gear-problem-1500-classics.html
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
1996 Kawasaki Vulcan 1500 Classic Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 30, 2012 | 1996 kawasaki VN 1500 Vulcan Classic
Shifter won't disengage 1st/can't change gears
pull out the cup holder just a head of the shifter you will find the shift cables at the shifter end see if they are poped off there
May 26, 2012 | 1996 Saturn SC
Saturn 1996 SC2 5 speed driverside shifter cable stuck not broken but wont move
Check the linkage at the tranny... make sure that the levers can move. It sounds like they may have messed up their proper positions.
Apr 12, 2017 | 1993 Saturn SC2
How to decalcify?
1. place water and descaler solution into tank
2. remove milk frother from arm
3. place a jug under steam arm
4.hold down the button 2nd from the right next to the menu button for a few seconds.
5.descaling machine open steam knob will appear on the display
6. after descale has finished "fill water tank" will appear.
7. refill tank with clean water no descaler
8.press the button 2nd from the right as in step 4
9. rinsing machine will appear.
10. when finished"close knob"will be displayed
11. refill water tank
12. ventilate will appear on the display
13.press the hot water button and allow to run
14.ventilate will disappear,warming should be displayed.
15. job done !!!
Jan 27, 2010 | Gaggia Titanium Espresso Machine
Grinding between 1st and 2nd gear
The syncro is about $185.00 and labor is hard to say, if it's been grinding and damaged hard parts tthere will be more money for parts and may mean the transmisson has to come out, and thats more money so it could get as high as $500.00 or more depending on what it needs. It's hard to say without tearing it down and looking at the parts.
Aug 28, 2009 | 1995 Nissan Pickup
Trouble shifting gears. Gears grinding while shifting from 1st to 2nd. Also cannot down shift from 2nd to 1st unless going less than 10 mph
YOU NEED TO TAKE YOUR TRANS OUT AND HAVE IT REBUILT, THE SYNCHROS ARE WORN OUT!!
THAT IS WHY YOU HAVE TROUBLE SHIFTING GEARS!!
Jul 01, 2009 | 2001 Dodge Dakota
I can't update the firmware on my forerunner 405 . The watch gives a transfer unsuccesful message, have tried repeatedly.
There are two steps for the firmware update - two bad Garmin doesn't warn people upfront.
The first update is preparing for the ANT stick - it takes about two minutes.
The second step is the core of the firmware(software per Garmin) update which takes about 10 to 15 minutes depending on how busy the Garmin Connect site is.
Since you already got through and got the "unsuccessful" message, I assume you already know how to start the update properly.
To finish it - Make sure you do not interrupt the process, just let it run through the 2 steps mentioned above.  And be patient - the 2nd step follows the 1st step automatically.  Don't touch the bezel and change screen during the update, just leave it alone.  It took me a few times to get it done successfully because after the 1st step finished, I started to flipping screens to find out if it get updated to ver 2.50, before I found out there would be step 2 coming automatically.
If you see the process bar moving after the 2nd step and see "software loading" you are in for good.
Hope this may help.
Jun 07, 2009 | Garmin Forerunner 405 Handheld GPS...
Auto trans grind when shifting from 1st to 2nd and downshifting from 2nd to 1st
Check the fluid! Had similar problem, $0.87 in fluid fixed it.
May 07, 2009 | 2000 Jeep Grand Cherokee
Joyoung Automatic Household DJ12B-A603DG Dry Beans No-Net Soy Milk Maker Logo
468 people viewed this question
Top Joyoung Wine & Spirits Experts
Don Hart
Don A
Don A
ray gallant
ray gallant
Are you a Joyoung Wine and Spirit Expert? Answer questions, earn points and help others
