Washer will not run
f06 OR e02 error code means you have an interface communication error. the main control board isn't communicating with the front interface control board. if you pull the washer out and remove the 3 screws coming in from the back of the top panel. the top panel will pull straight back, up, and off. check all the wire connections between the two control board and make sure they are all secure. if everything looks good, then the interface control board may need to be replaced.
f01 e02 means that your motor control board is not reading the tachometer on your motor when it tries to turn the motor. it thinks that the motor is struggling. open the door and turn the basket to make sure it spins freely.
