Televison & Video Logo
j
jaco laubscher Posted on Apr 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red on LG rt-54na21t convergence out of line now
Blue and green ok
  • jaco laubscher
    jaco laubscher May 08, 2014
    I replaced the ic and my problem is fixed thanks .. for the help .
  • Jack South May 08, 2014
    No problem. Glad to help. Since I am now partially disabled I can't work much--and this is one way to use my 27 years of experience
Jack South
Level 2:
Scholar:
  • Expert 195 Answers
  • Posted on May 08, 2014
Jack South
Expert
Level 2:
Scholar:
Answers
195
Questions
0
Helped
35501
Points
350
Probably a bad red convergence chip.
Gcotyelwa Mnqandi
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 27, 2017
Gcotyelwa Mnqandi
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
123
Points
Hey my RT-54NA21T LG TUBE TV JUST STOPPED working SWITCHES ON BUT BLA?K SCREEN NO SOUND HELP PLZ
5 Related Answers
Anonymous
  • 398 Answers
  • Posted on Jul 15, 2007
SOURCE: 43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Apr 16, 2008
SOURCE: Mitsubishi Projection TV HD1080
you need to replace your convergence ICs. Post your model number of your set, and I will post the correct stk numbers and a link where you can get new ones.
Anonymous
  • 70 Answers
  • Posted on Oct 15, 2008
SOURCE: lg rt 56nz23rb
Hi there.
Replace the stk convergence ics and also the 3.9 0hm fusible resistors.
Anonymous
  • 1959 Answers
  • Posted on May 23, 2009
SOURCE: Convergence is off - Blue and Red are fine Green will not line up
On most units, the Green is constant and the Red and Blue are adjustable. Here are 2 links on how to manually adjust the convergence. There is a menu option using the remote control. Once there, you will find step by step procedure on how to adjust the convergence. Hope this helps answer your question. All the best!
Greg
http://www.fixyourowntv.com/menumitsubishi.php
http://www.ehow.com/how_2034880_perform-convergence--tv.html
Anonymous
  • 14553 Answers
  • Posted on Nov 10, 2009
SOURCE: Unable to move the blue and red convergence lines to the green
If red or blue will not move this model uses two of the STK-392-110 CONVERGENCE CHIPS.
Both chips along with any of the 8 or 10 protect resistors around need to be replaced--the parts are cheap--you can buy a pair of the chips on Ebay for less than 14 dollars plus shipping and the resistors are easy to test and or replace if gone.
Total parts cost should be under 30 dollars.
The hard part of this repair in your set is getting at the chips to replace them---most of these sets you have to unbolt the entire chassis--you will have to mark and unplug several plugs---so that you end up with the bottom of all the boards facing the back of the set.
Both chips are black in color--2 1/2 inches wide and 1 1/2 inches tall with 18 pins each--you need to be able to get at them, un-solder them and replace them.
They usually are near the middle of the boards and are on two large metal heat sinks with fins side by side and will have the STK-392-110 PRINTED ON THEM IN WHITE.
The resistors are dark gray in color an are usually 1.8 ohm in value---they can be tested with a meter---like checking a fuse--one with no reading is open. They usually do not burn or discolor in this set.
Most of the time just the chips need to be replaced and then the set adjusted--you will get ok results in the customer menu and if you get it working I can give you instructions to get into the TECH menu for fine adjustment all over the screen.
I am willing to step you through this repair if you or someone you know can do it---I will tell you all the things you need and give general instructions depending on where you find the chips are located in your set.
This repair usually takes me less than 1 hour, but I have done hundreds of them---someone else here with a similar set and problem I helped recently was able to do this repair--it took him over 2 or 3 hours since it was his first time.
If you cannot do the repair let me know and I will give you options.
If this information helped you, rate this solution as I DO THIS HERE FOR FREE.
SD TECH
Lg 55lv6300 has red and green vertical lines help
On other panel TV's this is known as a convergence problem. You have to get experienced help costing about $150 or do it yourself. TV's that age have this issue, and you have to open the Tv and find the voltage/convergence box with three screws on it. It usually has blue, green and red adjustment screws, with red on the right. So go for the green and red and adjust until the issue goes away.
2answers
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Panasonic Model #PT51HZ41E Blue is not converging, red and green perfect. Blue lines move but will not converge have replace STK392-110 checked all resistors what else could the problem be
On my Panasonic PT-56TW53, the down left quarter of the screen has a big colour distorsion. Convergence can adjust blue and red, but green is not able to show a straight line. Is tis a mechanical adjstment? Help would be great.
I can set convergence lines on red and blue lines. the
Replace both of your convergence ICs they are big black ICs will have STK392-110 on them Call Mats 1-800-628-1118 10.95 each.
3helpful
Our L.G tv ( model RT-44NA11T)has color problems.
If your TV is not DLP, replace STK ICs convergence.will have part # ON THEM . Projection has 3 tubes a red/ a blue and a green TUBE ---DLP has 1 Lamp.
1helpful
Lg rt 56nz23rb
Hi there.
3helpful
Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
2answers
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
2answers
Converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
