I just moved and plugged in my GDM12 TRUE cooler and it runs, but I hear a click followed 5 seconds later by another click. This continues non-stop. Unit has set for a month after a thorough cleaning of underneath. Any ideas?
Clicking like this is usually a problem with the compressor start device. They are prone to failing and the overload protector is cycling to hopefully protect the compressor from burning out. If the start device is a solid state device if you remove it from the compressor it should not rattle. If it does it is bad and will need to be replaced. Installing a new strat device should get it back up and running.
SOURCE: true freezer
Just to make sure--is the freezer plugged into a GFI outlet and is the little red button pushed in? Is it on it's on circuit and has it thrown the breaker?Have you tried a different outlet? Do you have any lights at all- showing power? did you have a power outage? If you had apower outage and it ruined your freezer, your homeowners insurance may cover it. I would have it looked at for an estimate.Ask ahead what a service call costs, and make a decision from there.
SOURCE: true gdm12 evap fan runs all the time evev with
evap fans will run continuiously on this unit,it is normal. fans stay on to circuilate air evenly inside unit.
