SOURCE: lg lsc27910tt water/ice dispenser sticks in the on
I had the same issue with mine but it is fairly easy to fix, all you need is patience.
1. Press the "Lock" button to ensure nothing is dispensed while performing the fix (worth testing).
2. Remove the grey rubber push from the dispenser carefully (give this part a wash in warm soapy water and leave to dry).
I used a small flat bladed screwdriver but BE CAREFUL not to damage it on removal.
3. Spray a small amount of WD40 (or similar oil) using the straw attachment into the mechanism, especially the spring.
4. Work the mechanism a few times (observe point #1) to ensure it is not sticking.
5. Get a chair.
6. Re-fit the rubber surround following these tips:
a) Starting at the top on the right hand side start gently pushing the rubber lip into the chrome surround.
b) Ensure as you work around the rubber that the legs locate into the holes (use the small screwdriver to guide them in).
c) Work around clockwise using the screwdriver to ease the rubber into the chrome surround.
d) Once in place you can work around again with the handle of the screwdriver putting slightly more pressure on the edge of the rubber (where it meets the metal surround, this will ensure that it locks back under the lip.
***Be patient when refitting the rubber part, it takes a good 15-20 minutes but not doing it right will result in more problems***
Hope this helps!
