see this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be
turned off or defective. Test the switch with an Ohm meter or continuity
checker.
If the vacuum cleaner motor does not run the motor itself might be
burned out. Check the power switch first to be sure the motor can get
power. Then, be sure the motor shaft can turn freely, that nothing is
obstructing it. If the motor can turn freely and is getting power but
still won't run it will need to be replaced.
