Last night I set for 365 and next thing I knew it was very hot and a fryer thermometer showed upwards of 400 deg. Is there a part that can be replaced to fix this problem?
SOURCE: Need instruction book for Euro-Pro X, Model F1066
Welcome to Fixya! I am the expert that picked your problem to solve. Here is the link to view and download your manual:
http://www.euro-pro.com/europro/manuals/F1066.pdf
Thanks for using FixYa.com
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further. I am at your service.
SOURCE: Euro-Pro fryer doesn't return to temp after cold food drop.
If your timer is connected to the t'stat, you may have an expensive project on your hands. However, in the meantime, I would just get an egg timer or a digital countdown timer and use it since it seems to operate fine without the timer.
SOURCE: Where can I get a
there are no inside parts made for this unit , you might call home shopping channel there might be a service center somewhere . if anyone would know its them
SOURCE: I have a euro pro
Hi there.
If the thermostat can not regulate the oil temperature anymore, that is the time to replace it with a good one.
Regards.
