The machine appears to be washing fine but when I get the washing out some items have dirty marks . they almost appear like they have been lying creased in a pool of dirty water . Imagine screwing a clean white cloth up and dipping in light mud and then opening it up. It ruins the clothes as although the stain lightens after further washes it never disappears completely. I don't overload the machine and this happens every 5 to 10 washes rather than every time. Cleaned out the drawer and pump but can't find any fluff filter so Help!
SOURCE: dirty washing
what this could be is your bearings check if there is any amount of movement from the drum by opening the door place your palm onto the front of the washer so its on the bodypart of the washer now place your fingers into the washer facing down so you can grab the drum with them now pull up and if there is any movement then its confirmed bearings need replacing m8 get the warranty company out its a big job some companys just replace the washer m8.It will be the bearings though what those black marks are is the grease out of the bearings cause the seal has gone ive done hundreds of bearing jobs let me know how u go on m8
SOURCE: I have been getting brown stains in the shape of a
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of clothing. I have no idea what is causing them - I have manually cleaned the inside of the washer. same thing here. I have been having this problem for a few weeks, cant wash anything white without ruining it.
SOURCE: smell coming from washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
SOURCE: My Washing machine stains clothes;
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
