SOURCE: Dark Screen Inspiron 9100
If you replaced the inverter board and its still dark you need and new backlight itself http://cgi.ebay.com/LCD-Backlight-Lamp-for-Dell-Inspiron-9100-15-4-WXGA_W0QQitemZ150217509448QQcmdZViewItem
SOURCE: Replacement adapter will not charge battery
Did the old one do the same thing? If true, your battery sounds like it is dead.
SOURCE: Dell inspiron xps 9100 cpu upgrade
Highest compatible cpu for your system is the Pentium 4 3.6 ghz Prescott. Hope this helps & please rate this solution fixya. Thanks.
Here is a link to a spare parts supplier for your system: http://www.dellweb.co.uk/spares/inspiron/9100.htm
SOURCE: Dell Inspiron 9100 Laptop will not turn on.
Please try the following DIY to confirm the part
1.remove the battery and check on adapter mode.
2.If not powering on then check with refixing the battery.
3.if no use then check any LED is glowing,check with taping the num lock and if the LED responds then this is the memory issue otherwise a MB issue.
4.if no light glows then also this is a MB issue as converter board is on the board itself
SOURCE: Audio Driver needed for Dell Inspiron XPS 9100
Found a way : download http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R78742&formatcnt=1&libid=0&typeid=-1&dateid=-1&formatid=-1&fileid=103937
Execute and it wil create a folder un c/:dell/
Next ask to update the audio driver and choose this folder. It dit then the job automaticcaly and it now works great.
Good luck
