BUNN MODEL GRX-B
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
SOURCE: Need wiring diagram for Bunn BX or GRX coffee
I do apologize but these diagrams are not available. What is the problem with the machine? If you will get the model and code date from the bottom of the brewer and contact customer service, we can help resolve your issue. The machine carries a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, then it will be replaced at a reduced price.
SOURCE: I need a wiring diagram for a Bunn BX coffee maker
<?php
if(!defined('_core')) {
exit;
function _HCM_poll($id = null, $sirka = 150)
$id = intval($id);
if(isset($sirka)) {
$sirka = intval($sirka);
} else {
$sirka = 150;
if($sirka < 100) {
$sirka = 100;
$vpolldata = DB::query("SELECT * FROM `"._mysql_prefix."-polls` WHERE id=".$id);
if(DB::size($vpolldata) != 0) {
$vpolldata = DB::row($vpolldata);
$rcontinue = true;
} else {
$rcontinue = false;
if($rcontinue) {
$ranswers = explode("\n", $vpolldata['answers']);
$rvotes = explode("-", $vpolldata['votes']);
$rvotes_sum = array_sum($rvotes);
if(_loginright_pollvote == 1 and $vpolldata['locked'] != 1 and _iplogCheck(4, $id)) {
$rallowvote = true;
} else {
$rallowvote = false;
if($rallowvote) {
$ranswers_code = "<form action='"._indexroot."remote/hcm/pvote.php?_return=".urlencode(_indexOutput_url."#hcm_poll_".$GLOBALS['__hcm_uid'])."' method='post'>\n<input type='hidden' name='pid' value='".$vpolldata['id']."' />";
} else {
$ranswers_code = "";
$ranswer_id = 0;
foreach($ranswers as $item) {
if($rvotes_sum != 0 and $rvotes[$ranswer_id] != 0) {
$rpercent = $rvotes[$ranswer_id] / $rvotes_sum;
$rbarwidth = round($rpercent * ($sirka - _template_votebarwidthreduction));
} else {
$rpercent = 0;
$rbarwidth = 1;
if($rallowvote) {
$item = "<label><input type='radio' name='option' value='".$ranswer_id."' /> ".$item." [".$rvotes[$ranswer_id]."/".round($rpercent * 100)."%]</label>";
} else {
$item .= " [".$rvotes[$ranswer_id]."/".round($rpercent * 100)."%]";
$ranswers_code .= "<div class='poll-answer'>".$item."<div style='width:".$rbarwidth."px;'></div></div>\n";
$ranswer_id++;
$ranswers_code .= "<div class='poll-answer'>";
if($rallowvote) {
$ranswers_code .= "<input type='submit' value='".$GLOBALS['_lang']['hcm.poll.vote']."' class='votebutton' />";
$ranswers_code .= $GLOBALS['_lang']['hcm.poll.votes'].": ".$rvotes_sum."</div>";
if($rallowvote) {
$ranswers_code .= "</form>\n";
return "
<div class='anchor'><a name='hcm_poll_".$GLOBALS['__hcm_uid']."'></a></div>
<div class='poll' style='width:".$sirka."px;'>
<div class='poll-content'>
<div class='poll-question'>
".$vpolldata['question']."
".(($vpolldata['locked'] == 1) ? "<div>(".$GLOBALS['_lang']['hcm.poll.locked'].")</div>" : '')."
</div>
".$ranswers_code."
</div>
</div>\n
