Question about Casio Privia Px330 Px-330 88 Key Digital Piano New
Casio privia key unseat - Casio Privia Px330 Px-330 88 Key Digital Piano New
5 Suggested Answers
SOURCE:
  • 5603 Answers
SOURCE: I have a Casio Privia PX-320. The left side keys
Check that the front of the keys is not hitting the lower plastic case front. If they hit it, then you need to disassemble the case partly and see what has shifted. It is ALSO possible that something has caaaused the aftertouch sensor to move out of position and it is hitting the keys early. ANY of these conditions needs to be addressed before damage is done.
Posted on Dec 01, 2009
  • 5603 Answers
SOURCE: My Casio Privia PX-110 is playing two notes at
IF every key sounds like it is doing that, you may have two voices selected with one of them being transposed.
You may have an "effect" turned on that generates a chorus, layered or multiple voice sounds.
Posted on Dec 10, 2009
  • 5603 Answers
SOURCE: casio privia key issue
The only way to analyze this is to open the case. You may find contaminating material has gotten in, or broken part, or key slightly out of position on pivots or pivot plastic broken.
When opening, be VERY careful of the tender ribbon cables. Have a large work surface that you can unfold the top onto. Be careful to use correct screw lengths and thread in each place you removed.
Posted on Apr 27, 2010
  • 5603 Answers
SOURCE: Casio Privia PX-130, 8 months old: fluttering sound
If I were to venture an educated guess I would vote for failing filter caps in the power supply.
The power is likely collapsing under load of the speakers but headphones take much less drive.
If this has an external wall-wart power supply, you might try a new one IF the output is found to be under the rated voltage.
Internal power supply components are beyond those individuals that are not adept at electronics.
Posted on Jul 14, 2010
How can i do the reset factory for a piano Casio Privia PX-120?? It have the tone/settings button but not the function button. anyone know?
You don't need to reset factory.
You just need to change the setting of LOCAL CONTROL.
Lets start :::
While holding TONE / SETTING button,press key D#7 at 7th octave (highest octave on the right hand). Then release. That's all.
Then the sound must be heard..
Mar 12, 2015 | Casio PX120 Privia KEy ESSENTIALS BUNDLE
Casio Privia 410r Piano soft pedal problem
The Casio Privia 410r has two pedal jacks at the back. One is the sustain pedal, the other is the soft/sus jack. Please use the other jack if you want to use sustain pedal. Only 1 of the 2 jacks can be used.
However, if you have the optional sp30a pedal which plugs UNDER the piano instead, then only can you have 3 different piano pedals.
May 18, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
How do you connect a casio privia px 330 usb to ipad 2
Casio don't supply PX330 drivers for IPAD.
Get a Windows 8.1 tablet or connect PX330 to a desktop PC and use IPAD to Remote control that PC.
Apr 27, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
Is it possible to disable the speakers on my Casio Privia?
YES. Either plug in headphones into the headphone socket. There should be a switch on the back which disables the speakers as well. A simple ON/OFF switch for speakers
Aug 10, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
I have a casio privia px-130, and I'm trying to use it as a MIDI on FL Studio, but it won't show up in FL Studio. Is there a driver that I have to download?
Check the midi channel. It needs to sync to FL Studio. Channel settings you'll need to look up in the privia manual...can be laborious - but worth it in the end :)
Apr 19, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
Casio privia key issue
Apr 26, 2010 | Casio Music
How to adjust the metronome on casio privia
You hold down the function key/button and then use the PIANO keys with the "tempo" shown above them.
In that section of the keyboard, the C# key raises the tempo and the C key lowers it. You can also use the numbered keys in that section to dial up a particular value. Hold function down and strike the numbers you want then release the function key/button
I don't believe there is an adjustment for loudness of the metronome other than the overall loudness of the piano..
Mar 26, 2010 | Casio Privia Keyboard Case
Nov 30, 2009 | Casio Music
Casio Privia Px330 Px-330 88 Key Digital Piano New Logo
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
