Polycom SoundStation 2 Logo
A
Anonymous Posted on Apr 08, 2014
Ext. mic muted lights stills on
Wired mics
1helpful
Logitech G930 Echo problem
Check the device manager for duplicate devices and make sure that the on board devices are disabled
Beaches wont turn mic
I for 1 don't know. But try to go to www.Turtle Beach.com they can help you out. I have Turtle Beach Ear Force XC1 and my mic I can talk but I can't hear anything but if your mic isn't working properly try using a different controller. If that doesn't help try getting a brand new mic.
2answers
Wireless microphones vhf transmitter green light no sound
Either mic "mute" is on or mic capsule is dead...dropping these low-end wireless mic's are usually fatal. Upgrade and you won't regret it.
Microphone doesn't work on Logitech ClearChat Premium PC headset. I've checked jacks, mute switch. Ran Paretologic to install proper drivers. Is there an on and off switch for the microphone (not the...
If the mic mute switch is not on and there is no red light in the mic arm then its likely you have a check in the 'mute mic' box in your sound manager. Open Volume control, choose options->properties-> recording. Check for checks in the boxes and remove them. Also make sure the slider for the mic is about half way up.
Mic muted
Just check the button on the mic or the properties of the mic... from there only you can select the option to not mute.
My microphone use to work but now it says when i click control panel to go to the sound and i test it, it says your sound hardware cannot play sounds, it use to work fine. and its not muted because i...
the grey means its not finding the mic. plug the mic into another plug for the mic. if it still is not working then your mic card slot might not be working.
1helpful
3answers
Advent 5313
Make sure you have not started your WEB cam.
Start Skype then click on Tools - then Options - Audio Settings then select your Microphone.
Then click on Video settings - then select your webcam, your image should now appear.
Select your Receive and Show video options - suggest you use
Only people in my contact list
Click SAVE (your settings)
To add people to your Contact list - Click on Contacts (at the top) - then New Contact and follow the instructions.
You can also test your Skype by click on Echo / Sound Test Service.
If you still have problems, get back to me.
Have fun
Shure wireless UHF microphone
Make sure the microphone and the receiver are still broadcasting/receiving on the same channel.
Check that all of the appropriate connections are right from the receiver to the mixing board are connected as well.
I hope this helps!
God Bless you!
Audio feedis crossing with my speaker feed with and without the microphone plugged in.
Your mic still picks up sound when it's unplugged ?
As far as the other prob goes that sounds like howl round ( feedback ), mute the mic when not talking through it or get a mic with a cardioid polar response pattern ( just ask for a cardioid mic, can get a hypercardioid or supercardioid too but a cardioid would be best for your application, point the mic right at your speaking position with the back of the mic pointing at the speakers wich ideally should be behind the mic, this will help cancel out their sound, puting a limiter on the mic and setting it where it only starts picking up sound when you talk directly into it will help too, but the sure fire way to solve the prob is to mute the mic when not speaking into it. What you definitely don't want is an omnidirectional mic, for what you are using a mic for.
3helpful
2answers
Microphone isn't working with the computer.
1-select start2-select contrrol panel3-select sound speech and audio devices4-select sound and audio devices.5-confirm that mute box not signed.6-pres advanced in mic volume confirm mute box not signed7-select audio you will see capture screen in mic volume sign select.8-in default device press volume you will see volume control screen in mic volume confirm that mute box not signed
Top Polycom Lands Phones Experts
k24674
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
