Tv wont turn on. Red standby light is on. Tried using remote and manually.
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
SOURCE: Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
SOURCE: my power light on hitachi lcd is flashing red and
Sadly to the end I can now explain the "problem" of my question by myself ...
Because I'm was not sure if I can handle the "problem" by myself I gave the Screen to a technican at our City with all the Information I found until this point (By the way my suspicion was the defect of something at the power supply unit). Two days later he gave me a call with the information about the error: An error at the power supply unit - spare parts => 50€, Work => 200€).
Unhappily im not yet got at soldering on screens, but for 250€ i would have made a good course for this (and if I can establish i will learn it).
So now again a bit more objectively:
Error / Problem:
TV - Step 1: Power Off
TV - Step 2: Stand-By
TV - Step 3: Power-On
TV - Step 4: Short flashing picture
TV - Step 5: Reverse to Step 1
Solution:
1. Find the defect Fuse/Safe/...
2. Buy the Spare part at eshop2.euras.com
3. Change the parts -> et voilá
Hopefully I could have been a little help for someone.
With kind regards,
NatureOneFreak
SOURCE: tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Testimonial: "how helpfull thanku kindly !"
SOURCE: blue lights standby only no channel open
please confirm brand and model number so I can assist you
