Pride Jazzy 614 Hd JAZZY 614HD Logo
A
Anonymous Posted on Apr 08, 2014
Lights on controller flashing
When turning on the unit, the lights flash back and forth, then just shut off
Lawrence Oravetz
Level 3:
  • Pride Master 10,558 Answers
  • Posted on Feb 24, 2015
Lawrence Oravetz
Pride Master
Level 3:
Answers
10558
Questions
Helped
2699798
Points
29284
You can get the service manual from Pride's website. It will tell you what the flashes mean and how to fix it.
Whelan WSLWFP54-6 electric fireplace shuts down and flashing blue light appears on the control.
Question edited for clarity. It appears to be an electric fireplace.
Question moved from Television and Video.
Not much on fixing them, but it is a lock out situation.The best thing is to phone the maker.
https://www.google.com/search?q=Whelan+WSLWFP54-6+flashing+light
Why would the drivers side window control unit stop working and alternate flashing light after replacing the old battery with a new one.
the memory was probably erased when you replaced the battery, check your manual on how to program your windows.
Bad control module?
Propably this is the problem.A bad chip causes thsese..
2helpful
2answers
Jet 3 flashes "code 7".
The VSI joystick controller of the Jet 3 with a flash code of 7 LEDs flashing on the battery condition display indicates a possible joystick fault.
The most likely problem is with the joystick gimble. You can also get a 7 bar flash if the joystick is out of the neutral position at start-up.
Run the joystick in a circle and back and forth feeling for any sticky or broken/dead spots. Check to see if the spring and gimble come back to center when you release it. Turn off the VSI and try centering the joystick. Turn the VSI back on and see if you can get the fault to clear.
The only recourse is to have the unit rebuilt or replaced . A rebuilt VSI will run about $500 and a new one about $1600. For this reason it is best to check with your insurance before performing the work to see if its a covered item. Hope this helps
2answers
How to repair Samsung AQV 12 FAN Air Conditioner
You can turn off the Thermostat, and the powers switch on the furnance and turn the breaker off in the breaker box wait about 20 - 30 minutes and turn the breaker back on, and the power to the furance back on and the thermostat, this should reset the system.
Melvin
St Louis
3answers
Panasonic pt47wx52cf tv shut off and wont turn
Please count red light flashes and let me know. There would be long pause between flashes so count pause to pause. It is an error code of TV problem.
1helpful
3answers
Panasonic SA-AK17 MASH stereo system
That demo mode thing is painfully annoying. With mine, I had to hold the 'display/demo' button in for about 1 second and then the words "NO DEMO" appeared. That fixed it.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
