Question about Compaq Presario 700 470024-192 Notebook
Netbook won't connect to verizon
Connect to Verizon
My Verizon Blitz won't connect to my computer
Endless hours were spent trying to connect my Motorola Razr to my computer. This finally worked:
Go to Google Playstore on the phone. Download Motorola PIM (all upper case).
If you have an extended battery case/charger on the phone, remove the phone and insert the USB cable into the port on the top of the phone.
Or
Download "Airdroid" and connect wirelessly.
Nov 02, 2013 | Verizon Wireless PCD Blitz TXT8010 -...
Want to connect it to my verizon wireless internet box not the right cable
what kind of connector does verizon box have can you take a pic of both i will research for ya let me know
Feb 04, 2013 | Brother Rare Super Power Note Powernote...
I can't seem to remotely connect and view my lorex cameras. What am i doing wrong...it was working fine till I got Verizon FIOS
You may need to reopen the ports necessary for the Lorex to be available for remote viewing. You should be able to look at the function on the Lorex menu to get the port numbers, then call Verizon to have them forward the ports. Without port forwarding, your video stream is being blocked at the Verizon FIOS Modem.
Feb 01, 2013 | Lorex Home Security
Cannot connect through verizon dsl westell 6100g modem
Call verizon dsl and make sure you have your account username and password (given to you by verizon when the connection was put in your home) when you get them on the phone. also make sure you have the username and password for your Linksys device.
Aug 14, 2012 | Linksys Wireless-G Broadband Router
Unit see's KPC-650 but can't connect to ISP verion
Hi First, are the drivers installed so that you can see the network but you just can't connect to it? Is the card activated? To get the Pc card activated contact the service provider I assume you mean Verizon United States Verizon Wireless www.verizonwireless.com 1-888-466-4646 When your card is activated you should be able to connect to Verizon network, this will have to be done directly with verizon we can't do it for you.
Nov 24, 2009 | D-Link DIR-450 Router (DIR450)
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
Jul 25, 2009 | Sharp DVMX1U DVD Player
My verizon UM175 usb modem will not connect to my acer aspire one
- Verify the Internet settings of your USB modem by calling the Verizon support.
Feb 28, 2009 | D-Link DIR-450 Router (DIR450)
Verizon dsl - can connect to email but not internet
It's a setting that we'll need to change.
I can screen share with you if you like.
Just advise
Dec 28, 2008 | Verizon Communications Ethernet/Wireless-G...
Verizon Westell 327w modem cannot connect to internet
hi. i work for verizon tv, internet and phone. and the tech was wrong. it is the unit it self how old is it?
Aug 07, 2008 | Westell Wirespeed VersaLink...
Compaq Presario 700 470024-192 Notebook Logo
27 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
