Question about Yamaha RX-V1500 Receiver
RX-V1500 no longer powers rear surround speakers
3 Suggested Answers
SOURCE:
SOURCE: Yamaha RX-V1500 Shuts down after 2 seconds
This set is getting old and is in the Archives section of the Yamaha consumer guide area. But, you can still download the owners manual if you need one. If it is going into protection mode even when there are no speakers connected OR when the sound level is very, very low or zero it is not good news. Yes, unplugging the line cord will cause the protection system to reset itself. But, if it shuts itself off again soon after rebooting it is a sign of bad grease in the output stages -- in all probability. Let me explain: The audio output transistors are mounted to a large heatsink which keeps them cool during operation. They are electrically isolated from touching the heatsink by an electrical insulating washer. But, in order to keep them cool and allow for good thermal conductivity of the heat generated by the output transistors the washers are treated with a heat conducting grease. Over time this grease will dry out and lose its heat conductivity ability allowing the temperature of the transistors to rise; as the heat goes up they conduct more current and cause the protection system to activate and shut the set down (in order to avoid damage to the set). That is the most common cause of your symptoms. However, there are several other possibilities, but I give this explanation a 90% probability based on my experience.
Posted on Jun 17, 2007
  • 14 Answers
SOURCE: I have a Yamaha RX - V665 and the Right rear
Start by using an old test speaker and connect it directly to the right surround output with a short wire and monitor it.
If it sems to work with no issues, you either have a bad connection at receiver or speaker, or a break in the speaker wire somewhere.
If you have the same problem with the test speaker, you have a rgt. rear output issue in the receiver and it needs repair.
Hope this helps
Posted on Apr 17, 2010
My RX-V1500 Yamaha receiver shuts-off after 3 seconds .
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Apr 12, 2011 | Yamaha RX-V1500 Receiver
Yamaha RX-V995: Is there anyway to only listen to
Assuming you have the same Model Variant ( I'm not sure if Yamaha varies model from Country to Country) I just switch mine to effect off ( 2 Channel) to remove the surround component so that only A or B speaker pairs work.That should fix it unless I am mistaken.
Jul 19, 2010 | Yamaha RX-V995 Receiver
I have a Yamaha RX - V665 and the right rear surround works only part of the time.
Hope this helps
Apr 17, 2010 | Yamaha RX-V663 Receiver
Yamaha rx-v1500 no surround sound
Do you have the owners manual of this Receiver. If yes, then I can guide you the page numbers:
The memory backup circuits prevent the stored data from being lost even if the unit is set in the standby mode, the power cord is disconnected from the AC outlet, or the power supply is temporarily cut. However, if the power cut is more that one week , the parameter values will retun to the factory setting. If this happens, edit the parametets again.
Now you want to reset all parameters:
Use PARAM.INI ( see page 63)
First put the MEMORY GUARD to OFF position.
To go to the the above :
Make sure the OSD is displayed.
Set AMP/SOURCE/TV to AMP,
then press MENU to enter SET MENU
Reach Option mode/2
enter C) PARAM.INI
All the parameters where changes have been made from their original setting would be marked in Asterisk(*).
Make the changes required.
Hope this works for you.
Please do rate this solution and thanks for using FixYa!
Mar 04, 2009 | Yamaha RX-V1500 Receiver
I have a RX-V461 AV Receiver for my Samsung HDTV.
I don't have manual here, but try to go to Setup menu / Speaker setup / Manual Setup / Config and check if rear speakers are NOT set to None.
Nov 19, 2008 | Yamaha RX-V461 AV Receiver
Rear Surround speakers
Best thing to do is to put the unit in 5 channel or 7 channel mode. That will send left ch information to the front left and rear left speakers ( both will get the same information). Ditto with the right channel. The center channel will get centre channel information.
If all the speakers work, go out and rent TOP GUN. ( yes its old), BUT there are a few extreme scenes , one of which is the elevator scene, where the camera changes perspective and suddenly you hear the elevator doors close BEHIND you through only the surround speakers ( have the unit in surround mode....NOT 5 or 7 ch mode ). If this works ok, then you have no problems.
Remember, surround sound only produces information in the rear channels when the information is there. To check out the digital and DTS decoders, get an action flick. If you can, get a remote too, because that will unlock many features about the receiver that you cant get to with the front panel controls. Also go to yamaha and download the owners manual ( its free !!).....that should get you going.....
best of luck...
Rob
Jun 08, 2008 | JVC RX-880V
No sound back two speakers
After using the method of last resort (RTFM) I discovered that Yamaha 7.1 amps assign an order of priority to the speakers. The surround speakers have higher priority than the surround-back speakers. I had connected the rear speakers (in a 5.1 configuration) to the surround-back speaker terminals and since nothing was connected to the surround terminals the E-6 error happed on auto-setup.
I eventually fixed this by connecting the rear speakers to the Surround L/R terminals and then, via the manual setup menu, set rear surround = NONE. This causes the amp to route the rear-surround signals to the Surround L/R terminals. The auto-configure then completed successfully.
May 18, 2008 | Yamaha RX-V661 Receiver
No subwofer operation 2year old system
Some systems don't send signal to subwoofer if speakers in SPEAKERS SETUP are set to LARGE, they redirect signal to center and front speakers. Maybe that's problem.
Oct 07, 2007 | Yamaha RX-V1500 Receiver
No power
your set needs a tech due to excessive voltage the regulator got very hot causing it to damage when opperating systems a fan is needed to cool it off.goodluck.
Mar 29, 2007 | Yamaha RX-V1500 Receiver
Dec 12, 2006 | Yamaha RX-V1500 Receiver
Yamaha RX-V1500 Receiver Logo
54 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
