Have you tried tighten the spray arms? They may have come lose at the fittings so need to be tightened up. You can normally tighten them with your hand. Take any traps/filters out of the dishwasher and clean them. You may find answers here: https://www.maytag.com
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
you must prime all new installs on dishwashers. this means you must put about a gallon of water in the unit on the first wash.pour a gallon of water inside the dishwasher on the bottom ,close the door and run as normal.water will start to come into unit.good luck with your project.
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them. If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged. Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
I would cheak your float switch witch is located on the bottom of inner dishwasher move it up and down may be stuck.then try.If that will not work you may have a bad micro door switch.Good luck:)
water level/float switch is stuck. (dishwasher is getting a indication the unit has enough water in it to operate)...repair/replace float switch, located in front right corner under bottom rack.
