Question about Lexar Electronics - Others
Jump drive wont format on win xp - Lexar Electronics - Others
  • Lexar Master
  • 3,324 Answers
What happens when you try?
Posted on Apr 08, 2014
SOURCE:
Can I change my windows 7 computer to XP with an XP disk
yes --
But you will loose all of your files and folders when you format the hard dive to install win xp
you cannot run 2 operating systems on the one hard drive unless the hard drive is partitioned ( in effect having 2 hard drives on the one disc) as it causes massive conflicts in operation
Why any one would install an out dated , unsupported operating system like win xp in place of win 7 beats me
of course if you insist in doing it you could always install and extra hard drive in the computer and run it as an extra hard drive and install the win xp on it and still retain all of your files and folders
Sep 09, 2017 | Computers & Internet
Data on clickfree is from my old XP, when i connect to my newer windows 7 computer, it wants me to format.
Win 7 doesn't recognize the format of XP drive. Put the Click drive on an XP machine on the network and copy files you need then format on Win 7 machine.
Mar 29, 2014 | ClickFree HD535 hard drive 500 GB USB
Windows xp file integrity failed in desktop
Hello Srinivas.
youre pen-drive "MUST" be formatted with " FAT32 " data system.
win XP "can`t read the NTFS format of win7."
(means also HDD`s to connect them with USB)
this works also for DVD and BR - players if they wont read an USB device.
Greet`s
Gue.
Jun 07, 2013 | Computers & Internet
Sudenly kingstone usb changed to skymedi and doesnt formated
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved.
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extract
How to use the software HP Drive Key Boot Utility
For Win XP, first way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win XP, second way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7, first way
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
I have a 40GB HDD with dual operating system Win XP & Vista. Now Win XP not work properly. So I have to format that HDD n install only one operting system Win XP. But Win XP bootable not work properly...
Hi and welcome ygshaikh !
Here is one solution ( there are maybe others ) easy to use if your pc is a desktop :
extract the hdd from your machine and connect it to a healthy computer ( in a external USB box or strait inside the pc ) . Format the drive and reinstall it in your machine . You will now be able to install Win XP .
Best regards .
Feb 14, 2011 | Computers & Internet
I want to install xp sp-2 32 bit on my lenovo g560 already having win7 32 bit can i install win xp ???? i want to format my only c drive and i want to keep both o.s. on my system. please help me.
you will not be able to do that because if you format c: drive you will loose Win 7, you can though, partition the c: drive and then add winxp to the new drive which should be d: drive now by booting from xp disk and choosing to install on d: drive only
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Dec 14, 2010 | Lenovo G560 06793JU Notebook
How do I format C drive with windows 7 on it I want to put windows XP on
hi
thank you for using Fixya
to formate C drive and re install windows XP
1 put widows XP CD in to your CD drive
2 restart your PC
3 it will boot your CD just put Enter
4 if not then selact boot option by presing F12 0r F2
5 it will start reding your CD
then just folow the instruction
it will ask you foue setps
May 16, 2010 | Compaq Presario CQ60-220US PC Laptop
Operating sytem problem
format ur drive where u install win server 2008...tats it..
Sep 22, 2008 | Microsoft Windows XP Professional
Pc won't load win xp
If you formatted it with fdiask it wont install on a fat format.
Dec 13, 2007 | Computers & Internet
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
Electronics - Others Logo
26 people viewed this question
Top Lexar Electronics - Others Experts
Ekse
Joe Negus
Joe Negus
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
