The rubber drive belt is burning up most likely cause by bearing going. The bearings are your ratteling sound and the burning smell is the rubber belt dragging.
The rubber drive belt is burning up most likely cause by bearing going. The bearings are your ratteling sound and the burning smell is the rubber belt dragging. The rubber drive belt is burning up most likely cause by bearing going. The bearings are your ratteling sound and the burning smell is the rubber belt dragging.
You can't post conmments that contain an email address.
I also have an X9i treadmill hardly used .smells like its burning. It also is not acting right while on it. Whats causing this? it cost $2000.00 no joke I thought Norditrak was a better company. I purchased it from Back country.
im not a dishwasher repair man but i know about mechanical and electrical equipment. sounds to me like a motor has burnt or burning out probably with one of the pumps. if its during wash then its the wash pump if during drain then the drain pump (im assuming these are two separate pumps)
if it smells like electrical burning or not like rubber then its probably your motor bearings making all the noise which means its not worth repairing.
