Thanks for your help, my problem is my canon iP3300 waste ink tank is full and the warning sign of servicing the waste ink absorber is needed. any solution please? i need the servicing code to reset the waste ink meter counter. thanks
SOURCE: waste ink tank full
You can try this
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Testimonial: "Very best solution!!!! Thank you very much !!! Good luck!"
SOURCE: how to reset waste ink absorber full ip3300 warning?
Try to enter service mode and reset EEPROM:
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head
Press RESUME 4 times then POWER to execute the command
turn the plug off turn on and all ok
putang inang yan.... ayaw talaga. anubayan???
what is the solution?
how to reset ink tank full cacon i860
how to reset ink tank full canon i860
waste ink tank full i860
how reset ink absorber counter?
I TRIES RESETTING BY HOLDING DOWN SERVICE BUTTON AND THEN HOLDING COLOUR BUTTTON FOR 5 SEC THEN RELEASE OLOUR BUTTON THEN RELEASE SERVICE BUTTON
replaced ink absorber need to reset
help please
how reset waste ink counter
