99 yamaha waverunner xl750. In 2007 it ran out of gas on the lake. Filled it with gas and put it on the lake 1 month later and it started ran good for about ten minutes slowly started sputtering then just idled and died off when throttled up. It would start but sounded jumpy and you could feather the throttle back and forth to get it going a little, but to much it would just die, stored it away and am tring to get it going now it just wont start
Sounds like you blew some junk up into the carbs or injectors whatever the casse maybe. if you can try to blow some air through system or get a good cleaner and run it through the system, if its not too bad that should take care of it. These dont like running out of gas, try not to do so in the future. 1 more thing, sometimes a blast or two of ether will help also. Good luck
