I cannot see anything on the lcd screen whatsoever it is pure white screen, the camera works fine except for this
SOURCE: How to replace lcd screen in Canon 20d
I FOUND A GUY THAT USES NAME BRAND LCDS AND REPAIRS OR SELLS YOU THE LCDS NEW, AND THERE CHEAPER THEN ANYONE IVE FOUND, HE HAS REPAIR 3 FOR ME SO FAR. IF YOU CAN DO IT YOUR SELF YOU CAN SAVE 20-30 CAUSE THATS WHAT HIS LABOR COST IS PLUS FREE SHIPPING. http://j2agent.googlepages.com
SOURCE: sd800 new lcd, displays all white
Sounds like the LCD ribbon cable is not seated properly in the connector. Did you unlock the cable before disconnecting the old one and then lock down the new one? Try taking it apart and putting it back in again.
Is there any damage to the ribbon cable or the gold contacts at the end of the cable? If so, the LCD is ruined and not useable.
If you like we offer an LCD installation for only $25 if you already have the LCD. Google search "digital camera parts", we are first on the list: Darntoothysam com
If we can help please let us know!
Thomas D.
Owner, Darntoothysam com
SOURCE: Canon EOS Digital Rebel XT: The upper lcd screen info flickers
It seems you have a false contact in the upper LCD screen, its flat ribbon cable or the connector at the main board.
It is necessary to open it and check it.
It is fairly easy to do it, but if the camera has a warranty, I do recommend you to make it valid.
If does not have warranty, then you may try in do it yourself if you have some experience and skills to fix electronic devices, or pay to have it done.
Best regards,
SOURCE: LCD screen will not display picture to be taken in
See this link. The symptoms you describe indicate that the image sensor (CCD) has failed. Canon will repair this at no cost, regardless of warranty status. Contact them as shown if you are in the US. Contact your regional Canon service facility if not.
