There are few possibilities that can cause engine misfire
issues. It can be issue with spark plugs or faulty spark plugs. Also get the
compression test done for cylinders. If any of cylinder shows low compression
then required, then that particular cylinder will cause misfire.
Also get obd codes scanned, the error code will let you know
which cylinder is misfiring or all cylinders are misfiring.
For your trouble shooting I suggest you to refer the help
oinks below. It has step by step details for many engine misfire issues.
Click the link below:-----
Ford Explorer Cylinder Misfire?
http://whoisbyme.blogspot.in/2012/06/ford-explorer-cylinder-misfire.html
Engine Misfire codes on Chevrolet Malibu?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Cylinder 6 Misfire?
http://howtobyme.blogspot.com/2011/12/cylinder-6-misfire.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Ford Explorer 5.0L: Engine Miss?
http://whoisbyme.blogspot.in/2012/06/ford-explorer-50l-engine-miss.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
Can cylinder misfire Damage the Catalytic converter?
http://schematicsdiagram.blogspot.in/2012/02/can-cylinder-misfire-damage-catalytic.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Chevrolet K1500 No spark, random misfire
http://repairhelpcenter.blogspot.com/2012/11/chevrolet-k1500-no-sparkrandom-misfire.html
2004 Ford F150: Engine Misfire and Lean Code?
http://whatisbyme.blogspot.in/2012/05/2004-ford-f150-engine-misfire-and-lean.html
1995 Toyota LS: Misfire at idle or low RPM
http://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Toyota Corolla:
Random Misfire?
http://technoanswers.blogspot.in/2012/04/toyota-corolla-random-misfire.html
2006 Ford Freestar: Misfire on Cylinder Number 2?
http://whatisbyme.blogspot.in/2012/06/2006-ford-freestar-misfire-on-cylinder.html
This will help.
Thanks.
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Engine Misfire codes for
car?
Engine Misfire codes?
This will help.
Thanks.
