SOURCE: water in bottom of dishwasher; seems to be
does it have a separate drain pump? when you look under it, is the drain line connected at front right corner of pump housing?there is a check housing in the tube that the drain hose connects to. it unscrews and has narrow opening on threaded end..may be blocked there.
SOURCE: WIRLPOOL DISHWASHER COLD WATER CLEAN ONLY!!!
HI Nick- the element in the dishwasher dries the dishes and sometimes boosts the heat of the water. Your water should come in already hot, so the problem is either your hot water heater or that the plumbing line was switched to cold by mistake. Or that people are bathing, laundering, etc. and using all available hot water right before you run the dishwasher.
SOURCE: whirlpool dishwasher wont wash
if the bottom tub is filling with water but not washing the issues is with the wash motor, some of this model use a start capacitor that can fail, if it has a capacitor on the side of the motor it may have failed but are difficult to diagnose but are cheap to replace so worth trying, if this doesn't help or if it doesn't have a capacitor then the fault is with the wash motor.
Testimonial: "I'm going to spend this Sunday morning uninstalling completely and checking out the motor...and...if present....the capacitor. If it has a capacitor I'm going to try replacing that....if not....I'm not going to try replacing the motor... For about $100 more I can buy a bran new dishwaher. This one is only 3 years old....Very disappointed in my first whirlpool product....but a new one could be the way to go. I can install that myself no problem. Thanks so much. I'll let you know if it was the capacitor"
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
