I have a similar problem with HULUplus - I think I'll return the TV to WalMart and try another brand. It's the second VIZIO I bought in the last 5 mos. that has had issues. The first TV had popping (sounded electrical) sounds, also cut out sometimes. Would U-Verse have something to do with it? That may be a dumb question, but who knows?
sounds like a pain ..have you looked in the menu to see if you can shut it off ? try watching the tv with the batteries out of the remote to see if you have a fault with that .good luck farr64[colin]
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Have you tried covering the IR eye on the front of the TV when this starts occuring? Sometimes other devices in your home can emit infrared light that in rare cases can be picked up by your TV as a command from the remote. If covering the eye seems to stop the problem, I would say my guess is correct. If the problem continues even with the IR eye blocked I would say that the internal tuner of the TV might be defective. good luck!
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
