1/3 of the width of the screen goes blank. This has been happening for about a month, but with shaking the device it no longer corrects. The part of the screen with a picture looks fine, but rest is black What is causing this and how can it be corrected. It has only had 3 months of usage.
1.Press and hold, or slide and hold, the Power button for a full 40 seconds, even after the screen goes blank, then let go.
2.Press or slide the power button to restart if the device does not start up again on its own.
3.Let the device charge for 30 minutes, unplug it, and then try to restart again.
1) sometimes screen locking apps ch make your touchscreen u responsive.
Reboot your phone/tablet.
Press and hold the power button for 10 seconds or until your screen goes blank. Wait a min or two
and then power your device up normally using the same button.
2)Eject and remove memory card and sim card.attached to it. Also remove the battery for a few seconds.
3)Remove any cases their automatic screen wake/sleep feature can cause device to malfunction. Remove case perform a restart.
4)ADVANCE USERS ONLY
Hard Reset
If everything above jails you can do a hard reset. This will completely wipe your device and return it to its original settings.
Hold the VolUp&VolDown buttons at the same time then press the power button. This starts your device in recovery mode.
You can do a Wipe-Factory Reset from there.
Use the Volume up & Down buttons to navigate and press the power button to select.
BE CAREFULand DONT MESS with the other options or you may brick your phone.
These are different solutions. Not to be done at same time.
Hi, 1) You should try restarting it, maby that will solve the problem. 2) If that does not happen, then go to a computer specialist, there maby is something wrong with your Display.
Your husband switched the device off. If you give the power switch a short nudge only, it goes in and out of "stand-by" mode, it is not really switched off.
Try to slide and hold the power switch again, until after the power light blinks three times. Should happe after ~5 seconds of holding. The Kindle should restart now --- takes about a minute, but you will see a progress bar to keep you happy during the delay.
Make sure the device is charged and then slide and hold the on switch for several seconds. This will switch the kindle off (not just put it to stand-by as with a short flip of the switch). If it was off already, or after the above procedure, the same slide-and-hold will switch it on again (this may take like a minute or so).
If the software just hung and there is no electrical or mechanical defect, the kindle should be ready again
