American Standard 2771.002.021 Cadet 5' x 36" Bathtub, Bone Logo
A
Anonymous Posted on Apr 07, 2014
Where is the power plug for american standard jets
5 Related Answers
Anonymous
  • 35 Answers
  • Posted on Dec 16, 2008
SOURCE: I have an american standard
Check the air vacuum switch and line as you may have a air vacuum leak. The button that controls the on and off to the jets is an air vacuum switch....It may have a slow air leak in the line or connections that is activating the on and off control
Anonymous
  • 125 Answers
  • Posted on Nov 15, 2009
SOURCE: how to remove jets from american standard jetted
Jet trim usually unthread counter clockwise out of the wall fitting
uspartscente
US Parts Center
  • 719 Answers
  • Posted on Jan 12, 2011
SOURCE: My American Standard spa tub Williamsburg Elite
sounds like maybe the jet faces are turned off. see if they turn one way or the other and they may open and spew water out for you.
Anonymous
  • 4 Answers
  • Posted on Sep 03, 2011
SOURCE: My american standard jet tub will not turn on. It
' /* * For text ads, append each ad to the string. */ for(i = 0; i ' + 'Ads by Google' + '' + google_ads[i].line1 + ''; url = '' + google_ads[i].visible_url + ''; info = makeBoldAdWords(google_ads[i].line2) + ' ' + makeBoldAdWords(google_ads[i].line3) + '
'; s += url + info; s += ''; } s += ''; } document.write(s); G_GGL_SKIP += google_ads.length; return; } var G_MAX_ADS_WL = 1; google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#) google_ad_channel = "4447185069+1147946396"; google_ad_output = 'js'; google_max_num_ads = '1'; google_ad_type = 'text'; google_feedback = 'on'; if(typeof G_GGL_SKIP == 'undefined') { G_GGL_SKIP = 0; } google_skip = G_GGL_SKIP; // --> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); Problem with the American Standard Bathtubs / Whirlpools By bassassist69 on Sep 02, 2011
Hello: Please contact us at Wmerican Standard Brands and we will gladly help you.
1-800-442-1902
Monday through Friday
8:00 A.M. to 7:30 P.M. EST
Technical Customer Service
8:00 A.M. to 6:00 P.M. EST
8:00 A.M. to 3:00 P.M. EST Saturday
-Paul, on behalf of ASB
Anonymous
  • 4 Answers
Hello:
Please contact us at American Standard, and will be glad to assist you.
-Paul, Brand Marketing
on behalf of American Standard Brands
1-800-442-1902
Hydromassage 1063
Not normal for that to happen but the jet faces on the two back jets may be turned off or down.
Try turning the face of the jet clockwise and see if you get more water flow out of each jet.
Rod
US Parts Center
My american standard jet tub will not turn on. It is plugged in and power is going to it. I worked just fine and then it simply stopped. It does make a small clicking noise when button in tub is pushed to...
1-800-442-1902
1helpful
My american standard jet tub will not turn on. The power is going to it. It clicks when you mash the button that is in the tub. It does nothing but click. The model # is PUWWSCAS12598R
Hello:
1-800-442-1902
My American Standard spa tub Williamsburg Elite Model 2425E has a couple of the eight jets failing to jet, the two on either side of the rear left corner.
I have an american standard jet tub, but i lost
You can adjust the jets by moving the center of the jet around, if the center does not move, it is not adjustable, some jets have a pressure adjustment by twisting the center of the jet left to right. No manual necessary for this.
Mar 13, 2010 • Home
1helpful
How to remove jets from american standard jetted tubs for routine maintenance
2answers
My american standard jacuzzi tub is pluged in but jets won't turn on
check for power at plug in if power your vacume switch is probably out replace switch.
I have an american standard air tub and cannot get the air jets to shut off.  They turn off, but come back on automatically a short time later.  How do I shut the power off?
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
