Question about Dell PowerEdge Computers & Internet
No Boot device available Press F1 to reboot - PowerEdge Dell Computers & Internet
    Master:
  • 969 Answers
Computer not recognizing the hard drive. Look in BIOS to see if hard drive is listed. Reload system disc/CD.
Posted on Mar 14, 2016
2 Suggested Answers
SOURCE:
  • 60 Answers
SOURCE: dell poweredge 2600 server recently
Did you experience a power event? Go to BIOS (F2), and make sure that RAID is Enabled. If RAID got turned off (power event, BIOS reset), then it will give you that message. If RAID is already enabled, then you may need to repair your operating system. If something else happened (drive failures, drives removed, etc.), then the array may be completely gone. Call Data Recovery services if it is critical you retreive the data.
Posted on Aug 14, 2010
Startup screen
select the first boot option and press enter
Dec 02, 2013 | Gateway Computers & Internet
How do i get my HP pavilion 521n to boot DVD ?
  • Press the "F1" or "F10" key when the logo appears on the screen to enter the BIOS setup.
  • Navigate to the BIOS menu "Advanced" using the right/left arrow keys on your keyboard.
  • Get to the option "Boot Order" with up/down arrow keys, and press "Enter."
  • Select the first boot device under the "Boot Order menu option and press "Enter."
  • Select "DVD" from the list of available boot devices and press "Enter."
  • Press the "F10" key to save your changes and exit the BIOS setup. The computer will automatically restart and then will boot from the DVD.
  • Aug 05, 2013 | Computers & Internet
    My inspiron 531 says no boot device available
    Computer is not configured to boot from your hard disk drive (SATA 0),
    you need to go into the BIOS (set-up) menu and make that drive the fisrt boot device.
    Feb 15, 2012 | Dell Inspiron 531s Desktop Computer
    My desktop compaq presario s4300nx starts up , i can accses set up with f1 but cant start recovery with F10 however the F10 button works in setup, no good to me, ...i have recovery disks the pc just...
    you will need a Windows boot disk / Windows install disk / WinXP disk to reboot the PC and install / or repair your OS
    rescue disk will not boot your PC
    to enable that you need to enter the BIOS, press F1, F2 or Del to enter BIOS , then you need to look for the BOOT seq in BIOS, change that to CD DVD drive as the 1st boot device, Save and Exit and insert the boot CD and restart
    this should give you the solution
    Dec 16, 2010 | HP Compaq Presario S4300NX (DF216A#ABA) PC...
    OptiPlex GX110 PC Desktop: Hello.. I'm having Dell Optiplex machine.When I t...
    Generally an indication that the Hard Drive isn't detected
    Things to check, go to BIOS F2, reset defaults and reboot, see if the HDD is seen. If it is, the battery on the motherboard is likely dead and needs replacement (Watch battery at Walmart, 3 dollars)
    If the HDD doesn't detect after resetting the BIOS, then most likely a Hard Drive failure
    May 18, 2010 | Dell OptiPlex GX110 PC Desktop
    Wont boot,keeps asking 2 F1 then'start normally' screen then afta a while back to F1,
    your system has dropped into a "boot loop".. The best way to fix this is to place your Windows install disk into the machine, then reboot. Go into the BIOS screen and change the boot sequence so the PC boots from the cd or dvd drive then save and exit (F10). once the system gets to the "press a key to boot from cd" option, press a key and let the installation system start up. This will detect an exisiting installation BUT, when it asks if you wish to repair using recovery manager, Press NO.. Then it will go to the setup screen and ask if you would like to fix the existing installation, press YES and setup will replace the damaged system files and re-write the MBR. Let setup finish and remove the disk at the end of the installation then reboot. All should now be well and your files should still be available too..
    Dec 27, 2009 | Compaq Presario 5000 PC Desktop
    Selected boot device is not available
    I had the same issue with my dell dimension 2400. The issue I was having resulted in the connection to the drive was loose. Try taking off the side of the case, find the drives in question and reseating the plugins. My pc was quite a bit older though and i don't know if this will be your solution, but its worth a shot. You can even try installing a different cable and swapping to another power supply plug.
    Aug 10, 2009 | Dell Dimension 8400 PC Desktop
    Packard bell pentium3 windows me
    F1 is probably the key to enter the Bios setup utility. Press and hold the F1 key immediately after you start the machine. Go to the boot priority section, and set your CD-Rom as first boot device. Press f10 to save the settings and reboot with your recovery disk installed
    Apr 29, 2009 | Packard Bell iMedia SL 9553 (P660401806)...
    Ndevice available
    Press F2 go into the BIOS, check the hard disk settings, make sure it is set to auto (detect)
    Nov 08, 2008 | Dell Latitude C640 Notebook
    Cd drive changing
    Your computer cannot find The Hard-drive Or operating System.
    Your Primary Hard Drive, is reporting an error.
    Try changing the Jumper setting on this From Master To slave.
    ( jumper is amall plastic Block ) on back of drive.
    Then set your CD/DVD To Master.
    Mike @ Compurepair.
    Mar 14, 2008 | Audio Players & Recorders
    Open Questions:
    Dell Printer@^+[1]=855-221-4867@&@tech Support Phone Number Tech Support Number Dell Printer Tech Support Number+1(855) 221-4867 time to gayo independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus sare compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight. Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.anning functions. s are compact and lightweight dell printer configuration web tool dell printer default password dell printer document stuck in queue dell printer drivers dell printer drivers for mac dell printer error 004-321 dell printer error 009-340 dell printer error 016-302 dell printer error 016-302 dell printer error 0502 dell printer error 077-900 dell printer error 1203 dell printer error 900.57 dell printer error codes dell printer filter failed dell printer firmware error 900.00 dell printer firmware error 900.57 dell printer fuser error dell printer goes offline dell printer goes offline windows 7 dell printer goes to sleep mode dell printer green flashing light dell printer grinding noise dell printer installation dell printer jam problem dell printer job stuck in queue dell printer keeps calibrating dell printer keeps going offline dell printer keeps initializing dell printer keeps jamming dell printer keeps printing same document dell printer keeps saying downloading application list dell printer keeps saying left cartridge incorrect dell printer keeps saying offline dell printer keeps saying out of paper dell printer keeps saying paper jam dell printer network setup dell printer not communicating with computer dell printer not printing dell printer not printing black ink dell printer not printing color dell printer not recognizing cartridge dell printer not scanning dell printer not working with windows 7 dell printer not working with windows 8 dell printer not working with windows 8.1 dell printer offline dell printer only prints one page dell printer out of paper error dell printer pc life warning dell printer problems dell printer setup wireless dell printer tech support number dell printer there is a problem with the printhead dell printer troubleshooting dell printer will not print dell printer wireless setup dell printer wireless setup utility dell printer won't print dell printer won't print black
    Jul 23, 2019 | Dell Computers & Internet
    Computers & Internet Logo
    356 people viewed this question
    Ekse
    Clive
    Clive
