Question about CyberLink PowerDVD 6 Deluxe Full Version OEM for PC
Trying to play a dvd on my laptop, I'm required to enter an activation code
What is the activation code to play dvd on laptop
  • CyberLink Master
  • 2,013 Answers
If all you need to di is play DVDs, I would uninstall the Cyberlink software, and install the free VLC.
Posted on Dec 15, 2015
SOURCE:
What do I do about a wrong activation code?
You need to contact cyberlink support as your laptop has not been correctly registered. Did you have it online while installing it?
Customer Support CyberLink
Jul 04, 2014 | Toshiba Satellite Computers & Internet
Currently Region 2 - I want to make it region free
Manufacturers of DVDs and DVD players install codes that only allow us to play DVDs that are manufactured for our region. (For example, the U.S. and Canada are region 1, while China is region 6.) To make your DVD player region-free, you'll need to find the unlock codes that will allow it to play DVDs from all over the world. Below are some steps to help make your DVD player region-free.
Purchase or borrow an imported DVD. The only real reason to make your DVD player region-free is if you plan on watching imported DVDs. Locate your DVD player's brand name and model number. These can usually be found on the box the DVD player came in, or on a sticker close to the video inputs or on the bottom of the DVD player. Have your remote handy. You will need your remote to enter the input codes into your DVD player. Locate a Web site that can help you with the codes you need for your particular DVD player, since all DVD players have different codes. Try DVD Exploder or Video Help (see Resources below). Both have an extensive list of codes for almost every kind of DVD player manufactured. Enter your brand name and model number when prompted to do so on the Web site. If your particular model number is not available, try searching under the brand name. Sometimes you will be able to find a model number that is close to your DVD player's model number. Enter the codes into your DVD player with your remote. Be sure the DVD player's door is open-almost all codes require the door to be open. Test your imported DVD to see if it works, once you have entered your code into the DVD player.
Apr 18, 2013 | Samsung Black Slim External Usb Dvd Writer...
Require to unlock Region Codes for an RCA Portable DVD player code DRC6318E. Can you help please
I'm sorry for the difficulties you're experiencing in playing other region disc in the RCA Portable DVD player. Please follow the below steps to unlock the region code and check the operation:
  1. Turn on the player without any disc inside
  2. Enter the code "321 789 456" before the player menu appears
  3. Select 'all' in the appearing list for region free
  4. Turn the player off
Thanks for understanding. Please let me know the result after performing the steps. Also let me know if you require further assistance.
Sep 11, 2011 | RCA DRC6318E Player
My panasonic dvd/vcr combo displays the message DV D 2 in the display. Cnnot play DVD
Sounds like your remote code is different to what's in the unit's display (DVD 2). You can try to 'reset' the remote, by pressing (and holding) 2 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore your remote function back to your unit. If it does not, replace the batteries with new ones, and try again.
The remote may require a 'reset' of its command mode (to match the unit) whenever the batteries are replaced.
I assume you can play DVD by pressing the PLAY button on the main unit.
Apr 28, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
Please give me activation code for cyberlink dvd installation. Cannot play my lightscribe dvd. The system continues to ask for dvd encoder.
The program isn't the problem- it's your dvd players software. Try VLC Player- a free player that plays anything. VLC player has the DVD encoder hot-wired into the program so you don't have to download one.
Dec 15, 2010 | HP LightScribe dvd640i (DVD640I)...
Can play cd's but not dvd's, just a rythmic wirring sound and green activity light
Hey,
just looking at the specifications, it should work with All CD's and Read Normal DVD discs, the movies that you can rent and buy from any store but it appears its a combo drive (Cd burner, and a DvD reader) It will only read DVD-rom and maybe few other things but it wont play any r or rw dvd's. It might also read already burned dvd r and rw discs but it wont read a empty one.
if it won't read any dvd's it could be a dirty lens. here's a video on the cleaning, its annoyingly loud but shows how to clean the lens with rubbing alcohol.
may want to turn the volume down in advance:
its for a ps2 but the drive is basically the same, and you would clean the lens in the same way.
let me know how that goes.
Thanks,
Ekse
Jun 03, 2009 | Dell Inspiron 6400 Notebook
I have windows vista the dvd-rw that i burn does not play on dvd players
Not all DVD players will play rewritable DVD disks. Check for compatibility. Also, burned DVD's need to be "finalized" and the region code of the burner must match the player. Check your software docs for steps to finalize and setting your region code. If you are in the U.S. your region code is 1.
May 31, 2009 | Gateway Computers & Internet
Need valid activation code to unlock the full game of fate
Visit http://www.pcworld.com
Download full games and play without activation codes required
Mar 18, 2009 | Computers & Internet
Unblocking code
# Turn On unit
# Press the Setup button on the remote
# Navigate to the Preferences page using the Right arrow key
# Press the Down arrow once to enter the Preference page
# Enter 1, 3, 8, 9, 3 and 1 on the remote
# You will now see the current region code displayed
# Use the Up/Down arrow keys to select the region required or 0 for all regions
# Press the Play or OK button on the remote
Dec 27, 2008 | Philips Code Free DVD Player
I bought a DVD and I played it on my laptop. It worked on the laptop but when i put it into the DVD player it wouldn't play. So I tryed playing the DVD in the PC and it also worked on there. Again I...
DVD movies have region codes, and they typically only play on a player or DVD-ROM drive sold in the country where the DVD movie was sold.
The actual region code is in one byte on the DVD (digital versatile disc). The DVD player or drive has a region code in its firmware. Personal computer DVD-ROM players often have the code in the software or MPEG-2 decoder. The two codes must match for the player or drive to play the movie. The code is also printed on the back of a DVD package, superimposed on a small image of the globe.
DVD regional locking is used to control which DVD movies play in which countries or groups of countries. Movies are often released on different dates around the world. Region 1 has its own player that will only play Region 1 discs. Likewise, Region 2 players can only play Region 2 discs and not play any of Region 1's discs. The six codes are:
  1. United States and Canada
  2. Europe and Japan
  3. Southeast Asia
  4. Latin America and Australia
  5. Russia, rest of Asia and Africa
  6. China
please check the DVD region code again and what PLAYER u are using to play on PC / LAPTOP??
where did you buy the DVD player??
Jul 23, 2008 | Televison & Video
CyberLink PowerDVD 6 Deluxe Full Version OEM for PC  Logo
166 people viewed this question
Top CyberLink Computers & Internet Experts
Alli Abiola
Alli Abiola
Peter Dragonetti
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
