Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
A
Anonymous Posted on Apr 07, 2014
How to change message on answering service for v tech 5.8
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Vtech Master 102,366 Answers
  • Posted on Aug 07, 2014
Vtech Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442411
Points
622693
Enter the model of your VTech 5.8GHz system into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
How do I change the number of rings on my LG classic flip phone
In a normal call, it will carry on ringing until you answer. If you have a message service set by your teleco, there is often a setting in messaging set up voice prompts, but they are all slightly different. You get to them by accessing voicemail. On mine it say option 5 says "to alter your voice messaging system, press 5'. Contact your telco, they may be able to do it for you.
2answers
KX-TGA660 handsets - 3 of 5 wouldn't ring (no sound)
sounds like who ever installed your service was an amateur, all points should be gone over by a senior tech, piece by piece!!
I need help in changing my voice mail message on a Motorola VGA 4XZOOM phone.....please help
Hey Tony,
Changing the voicemail message is as easy as calling your voicemail, selecting SETTINGS from the main menu and re-recording the message.
The type of phone (equipment) does not matter .
If you have problems and are unable to do it this way , then dial 611 from your phone and talk to a service tech regarding voicemail (option 5 I think...?).
Sep 30, 2011 • Cell Phones
How do i retrieve messages when out of town, from my v-tech 5.8 & can i use my cell phone to do this ?
If I remember correctly you can remotely connect to your answering machine.
When you call the phone and it greets you (assuming you haven't changed the code) press 19 to get it going.
You should then begin to hear your messages. After you get past the 19 part (options are as follows)
1 ) Plays all messages 2 ) Plays only new messages 3 ) (During playback) Deletes the current message 33 ) Deletes ALL OLD messages 4 ) Repeats current message 5 ) Stop 5 ) (While no message being played) Lists Available Commands 6 ) Skips to next message 7 ) (While no message being played) Record new greeting 8 ) Hang up 0 ) Turn Answering Machine on/off
Does not wait for the 4th ring; sends call to verizon voice mail box after the second ring
Sounds like your service provider(Verizon) has your phone line setup to forward to voicemail on no answer after 2 rings. Call your service provider's customer service number and request that the number of rings for forward no answer be increased to at least 5, then your answer machine can receive and answer your calls after 4 rings but if your line is busy callers can leave a message with your Verizon voicemail service. If you don't want Verizon voicemail to answer any of your calls, you could have them disable the voicemail service. When you call the service provider have a recent bill ready because they may request your account number before they will make any changes.
1helpful
How to I change the receipt message with a Sharp er-a440?
Turn key to PGM2 mode 1. type 2614 2. press . (decimal point) 3. press X (next to decimal point - on USA model, labelled @/FOR) 4. now type the line number you want to change e.g 4 for fourth line 5. press X (next to decimal point) 6. now type the new message using the alphabet on the front edge of each button. If someone has removed the letters, you can find a layout in the operating manual under "USING CHARACTER KEYS ON THE KEYBOARD" 7. ST (subtotal) 8. TL (cash button)
If anyone needs / looking for a Sharp ER-A440 or ER-A450 manual,
Programming manual: http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-A440_and_ER-A450_programming_manual.html
440 Instruction manual: http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-A440_instruction_manual.html
440 service (repair) manual: http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-A440_service_manual.html
3answers
I left my Vtech phone in New York, left for Europe and forgot to set the answering machine on. When I call in I get a factory recorded announcement that I'm not available, etc. I have my PIN # with me,...
Can you please specify the exact model of the phone? Because the steps in accessing it remotely varies from model to model. Anyway, you can try to follow the steps posted here and then test:
Remote operation allows you to control the functions of the Answering System when you
are away from the Base,and call from an outside telephone line. The Answering
System cannot be accessed from another telephone on the same line. You can access
many of the Answering System functons from a remote location, such as listening to
messages, changing recorded announcements, and recording memos.
Remote operation can only be accessed from a touch tone telephone. If the remote phone
is set to pulse dialing, switch it tone. If tone dialing is not available, you will not be able
to access the Answering System.
Note: All function codes should be entered within 2 seconds in order to activate Remote
Operation.
To Activate Remote Operation From a Different Telephone Line
1. If the Answering System is OFF, you can dial your telephone number and wait for
the Answering System to answer your call after 10 rings. An announcement, "Please
enter your security code" is given, and you enter your security code to use remote
operation.
2. If the Answering System is ON, it will answer your call and begin playing the currently
selected announcement (as with any incoming call).
3. Enter # followed by your 2 digit security code during the announcement. The
default security code is 19.
4. Once the security code is received, a double confirmation beep will be given, and
you are in Remote Operation mode. You can then control the Answering Machine
functions using the telephone keypad.
5. The user can also enter the Remote Operation mode during message recording. The
procedure is the same as step 3. The recording will be stopped after entering the
valid security code "s#xx " and the incomplete message will be deleted. If " 0s"
is entered, the Answering System will release the line, but the recorded message
will still be retained.
6. If the user enters a wrong security code, the system will release the line.
Playing Messages Remotely
1. Press " #1 ", " #2 " or " #3 " on the touch tone keypad to play the messages in the
corresponding mailbox.
2. The system will announce "Mailbox X. You have XX new messages and XX old
messages" and the system will playback the new message only. If there are no new
messages, the system will announce "Mailbox X. You have XX old messages. On
the other hand, in the absence of old messages, the system will announce only the
number of new messages.
Repeat Messages During Playback
1. Press "#4" once during message playback to repeat the current message.
2. Press "#4" twice within 2 seconds to skip to the previous message.
Skip Messages During Playback
1. Press "#6" once to skip forward to the next message.
Stop Message Playback
1. Pressing "#5" during message playback will stop playback.
Deleting Messages
1. Press "#9" once during message playback to delete the current message.
Note: Playback will pause if "#" or " " is entered. Answering System will wait for the
command in the following 2 seconds. If no further tone is entered, playback will be resumed.
Memo Recording
1. Press " 8".
2. After selecting the mailbox by entering command "1", "2", "3", You will hear, "Now
recording", followed by a beep.
3. Enter "#5" to stop recording when you have finished.
Change OGM Remotely
1. Enter " 7" to record a new OGM. You will hear, "Now recording", followed by a
beep to signal start of recording.
2. Press "#5" to stop recording. Your new OGM will playback automatically.
Check OGM1 Remotely
Enter "#7" to review OGM. You will hear playback of OGM followed by a beep.
Turning Answering System ON or OFF
Pressing "#0" toggles the Answering System ON/OFF. "Answer machine on", or "Answer
machine off" will be announced, followed by a beep.
Voice Menu for Remote Operation
The system provides two pre-recorded voice menus to help you during remote operation.
Press " 5", and you will hear the simple voice menu.
The simple voice menu is as follows:
• Press "#1" to play mailbox 1.
• Press "#2" to play mailbox 2.
• Press "#3" to play mailbox 3.
• Press "#5" to stop.
• Press "#4" to repeat the message.
• Press "#6" to skip the message.
• Press "#9" to erase the message.
• Press " 5" for other functions.
(To advance voice menu)
The advanced voice menu is as follows:
• Press "#7" to review outgoing message.
• Press " 7" to record outgoing message.
• Press " 8" to record memo.
• Press "#4" twice to repeat previous message.
• Press "#0" to turn the system on or off.
• Press " 5" to return to the simple voice menu.
Pressing any function code will stop the voice menu, and perform the corresponding
functions.
Exiting Remote Operation
1. Enter " 0" on the touch tone keypad to exit remote operation mode. The Answering
System confirms your action with a long beep and then disconnects.
2. The Answering System also automatically disconnects if no key is pressed within 20
seconds during remote operation.
14helpful
4answers
How to change voicemail message. I have no manual. Thanks
I just looked up how to change it....press the mute button, the scroll left or right to reach recordpersonal message and press the menu key. when you're done recording press the 5 key to end it. Works for my Uniden DECT 6.0
2helpful
One tel magma 300 - can't change message on answerphone
1) Press the 'tape' symbol to access the answering machine mode.
2) Press 9 then 1 for 'answer and record'.
3) Whe you hear a 'beep' speak your message. Whilst recording the display shows REC OGM1 or REC OGM2
4) Press 5 to stop recording. Your message is played back to you
5) Press 'tape' symbol to exit.
To check your Out Going Message (OGM)
1) Press 'tape' symbol
2) Press 6 then 2 and the message is played back.
1helpful
ATT 5840
The processor chip that records the voice is a multi level SMD technology chip. The tech who changes it will need the proper soldering facilities for this type of work.
The only people who can service the phone are the authorized service people for ATT. They will not sell parts to non authorized service people, even if they have the proper facilities to change the chip.
For service on your phone, the service center will normaly change the complete circuit board. If the phone is out of warranty, the cost would not be worth it.
Jerry G.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
