Bobbin winder doesn't rotate motor is running but spindle doesn't turn
SOURCE: The motor runs but NOTHING moves, not even the
If the motor is actually running but nothing moving at all even the winder then either the belt is loose or it has come off.
SOURCE: bobbin winder won't spin Cannot load bobbin
Can be dirt or particles that have made it stuck with friction and so a resetting /overhauling with good oiling, degresing will resolve the matter, provided there is wearing off in the drive.
First use a degreasing spray before you can disemble.
SOURCE: My bobbin winder stopped working on my Brother
I think that I would call Brother at 1-877-276-8437 and ask them if this is a warranty issue. They may have a quick fix for you.
Testimonial: "Thank you. I am dropping it off at a nearby fabric store, and if they cant do anything, I will contact brother."
SOURCE: my bobbin winder will not work. I can hear the
Check the belt inside,might had came out or broken.Thank you.
SOURCE: Bobbin winder
then there is something wrong with the bobbin winder & it needs to be repaired
