When disassembled, small, silver, not smooth washer fell out from unit. Can't see where it fits. If for toggle switch, doesn't seem to be enough room.
SOURCE: my kitchenaid artisan coffee machine not enough water
if you have water out brewing without handle with coffee, than you check this 3 things:
SOURCE: Kitchenaid mod#KCM511 - error 2
An ERR 2 may be cleared by a simple reset of the coffee maker. This
means unplugging the unit and plugging it back in. When powered back
on, select a brew function to see if the error reappears.
If the code does reappear, ERR 2 indicates an internal error with the computer of the
warming plate. This may be covered under Kitchenaid's 1 Year Hassle
Free Warranty. I would advise you to call Kitchenaid Customer Service
to see what options are available to you. Repair is not recommended, as
it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
SOURCE: Broken shear pin in kitchenaid A9 Coffee Grinder
I was able to find 3/32 x 1/2 inch spring pins at a local hardware for 13 cents each. They may not last as long, but at the price I can replace as needed.
I also had to disassemble twice; I didn't notice that a portion of the old pin was wedged in the underside of the burr. When I put it back together the first time, the new pin rested on the old fragment and pressed the burrs too close together. On the coarsest possible setting, I got coffee powder!
Final note: The nut for the cap over the burrs is reverse-threaded...use a wrench on top, and a flat-blade screw driver in the slot at the bottom of the motor shaft.
SOURCE: KCG200WH1 model
If you mean a chrome with serrated edges then that is a screw type ring that screws on the toggle switch on the outside to hold the switch tight in place against the body of the grinder. Place the ring over the toggle and hold the switch in place and screw the little ring on until tight.
