Have 36 in monogram refridgerator.....after moving units to new location,door is out of plumb and will not close properly
You will need to adjust both door at the same time. You will need a 5/16 wrench. Loosen the hinge screws on the top. Try to line one door with the center post between the doors. Open it and see if it closes by it's self. If so, go to the other door. line it up with the other door, allowing about 1/2" between them. Now see if it will close by it's self. If not, you will have to play with it. The only other adjustment is on the bottom. You will need a3/8" wrench (some have 1/2" screws). loosen screws on one side, have someone pull door up until the top is even with the top if unit. Tighten and then do the same with the other side.Once you have this done, adjust the top hinges. Good luck.
