A
Anonymous Posted on Apr 07, 2014
Functional problem SC555 - Lanier Office Equipment & Supplies
paulfvincent
Level 2:
Champion:
  • Lanier Expert 208 Answers
  • Posted on Dec 14, 2014
paulfvincent
Lanier Expert
Level 2:
Champion:
Answers
208
Questions
0
Helped
58649
Points
249
What model? That is a fuser error code.
How to fix SC555 error ?
Same way you reset 542 enter service mode and cycle power
Lanier 450 SC555
Hot section problem, call the service guy
Sc555 on gestetner mp1600
Fuser problem. lamp stays on too long, probably a power supply
Service Code Error SC555. This machine is not connected to the network. There is not an obvious paper jam. Can you describe a possible fix. Carolann
SC 555 is the main motor error. the main motor needs replacing. its the only solution. the main motor fits at the back of the machine. if you open the back cover, you will be able to see it.
3helpful
Mp6001 with sc555 error code
Fusing lamp overheat error (rear)
555 A
After the fusing
temperature reaches the
target temperature, the
fusing lamp does not turn
off for 20 consecutive
seconds.
?? Fusing thermistor defective or out of
position
?? Power supply board defective
u need a servise engineer to reset/fix it
2helpful
2answers
We have a Ricoh aficio 2051sp with error code SC555 what does this mean?
you will need to remove these and test with a multimeter. we are in michigan do you need a ricoh copier service 248-677-8112
Ricoh 3800c Error code sc555
SC 555 Pressure roller
fusing lamp
When the fusing unit is not
running in the Ready condition,
the pressure roller fusing lamp
keeps ON with full power for
100 consecutive seconds.
Replace the fusing unit.
3helpful
2answers
Ricoh 3800c error code SC555
fuser related -- call tech to reset --- thermistors
Jam
SC555 is a fuser error there are a few possabilities that could have caused this..
1 You have a peice of paper trapped in the fuser unit(the heated rollers)
2 The fuser unit is not fully home
3 The thermistor/fuser lamp has a malfunction
Fusing unit SCs displayed on the operation
panel. The machine is disabled. The user
cannot reset the SC.
Turn the main power switch off
then on before entering SP mode.
Reset the SC (push "EXECUTE"
with SP5-810), then turn the main off then on again
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
