NEC PlasmaSync 42MP3 42 in. Television Logo
A
Anonymous Posted on Apr 07, 2014
Vertical line coming in onida tv - NEC PlasmaSync 42MP3 42 in. Television
Onida black 21 crt tv fault finding
Vertical scan output section circuit has the fault. Check it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Onida tv
If the line displayed is a very thin one, and across the center of the screen, it is a problem with its vertical sweep. Check and replace the vertical output IC. If you wish to get more details, and schematic similar to LG, check the site linked here. Check what is the IC number used with your TV. Check for it. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the Brand name to your set in its search box, or view it in Mosaic /Timeslide option.
Onida tv
Horizontal line on screen denotes the absensce of vertical sweep itself. Check the vertical output section circuit to LA7840. Check for any loose solder terminals. It will be best to measure the input voltage to that IC from the LOT secondary supply. Try by replace the IC. If these do not help you, measure the frequency from the main IC. It should be at 50Hz. If this frequency is not present, the main IC is faulty. If you wish to get some more details about the circuit, check this link. http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option. Schematic diagrams, that show vertical IC LA7840 is given. You can compare it.
1helpful
What's the code for universal remote?
sir i have onida 21'' tv thi tv vertical line smoll so i need adjest for v line. please tel me fectery setting code
3helpful
2answers
One horizontal line comes on screen model of TV is onida KY tunder
needs a new vertical chip call your local tv repair men to get the job done cheap
20helpful
6answers
Onida stand by problem
sir my onida tv 21'' ineed un lock
2answers
Onida Ky Thunder tv blackout
my onida ky thunder giving fault led blinking after plugin and after 5 second goes to stopped mode
Top NEC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
