Question about Xterra Fitness SB4.5r Recumbent Bike
After plugging the cord into the wall where do I plug the cord into the xterra for power to get the bike to run?
My power cord for the docking station is beginning to unravel with wires showing. Can it be replaced or repaired?
First, I know nothing at all about ipods. However, I am a decent electronics guy. Obviously, one end of the power cord plugs into a wall outlet; the other connects to the station. How? Does the cord simply disappear inside the station, or is there some kind of connecting plug? Which end is frayed? If it's at the wall plug end, you could simply cut the wire (unplug it first !!!) above the fray and wire in a new standard wall plug. You can do the same on the station end if the wire runs directly into the unit AND if you can get in there to reconnect the wire. If, on the other hand, the wire is attached to the station via some sort of power plug (like a printer for example), you'd better leave that puppy alone and invest in a new docking station or new power cord. You'd also better stop using the unit unless you can fix it. Bare wires spell tripped breakers and danger of injury.
May 28, 2016 | JBL ONSTAGE Docking Station for iPod
How can i get a power cord for my Swinn ex. bike?Estimated to be 5 Years old.
It would help to know what model bike You have because that model number can be given to any appliance parts dealer that You find locally, possibly even Sears, to get a replacement power adapter. I'm assuming Yours is like a small transformer that plugs into the wall outlet with a small cord that has a shiny metal pin on the end that plugs into Your Bike? Adapters for other Schwinn® and Nautilus® home fitness equipment can be ordered by phone at (800) 605-3369. Optional power adapter for the Schwinn® A40 elliptical, A10 and A15 upright bikes and A20 and A25 recumbent bikes. I hope that helps!
Feb 19, 2015 | Power Motorcycles
We had a power outage, now pixma Mx410 won't come on, any ideas?
Is pinter plugged into a power strip? Try plugging directly into wall. Make sure wall outlet is working correctly, try another item in plug in. Does printer have a power module or brick that is plugged into printer? That power module is there to protect your printer during a power surge, it may need to be reset. Is there a light on that brick or power module? If so, does it light up? If not, could be a bad power module. There is no such thing as "reset" button, so don't look there...It will have to be reset in a series of ways for an "external" module.
  1. Disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet, power strip, or surge protector.
  3. If the printer uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. If the printer uses a power module with a detachable power cord, reconnect the power cord to the power module.
  6. Reconnect the power cord to the rear of the printer.
  7. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  8. Check to see if the power module or the power cord has an indicator light and if it is on
For an internal module:
  3. Wait 15 seconds.
  4. Reconnect the power cord to the rear of the printer.
  5. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  6. Check to see if the power module has an indicator light.
Not sure if this will help you..but worth a try.....
Jun 15, 2014 | Canon Pixma MX410 All-In-One Printer
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Have a Sunrise Aspire chair w/new batterie, charged by the repairman. Want to keep it charged regularly (not let it run down). DO I NEED TO TOTALLY DISCONNECT THE POWER HOOKUPS IN THE BACK when I...
You do not need to unplug the large 9 pin beau plug in the rear or the smaller 3 pin molex plug when you charge the chair. Do not unplug them or you will not charge the chair.
Use your charging cord as you describe "plug it into the front, plug it into the wall and charge, then unplug the charger cord and GO". Hope this helps.
Jan 05, 2011 | Quickie Wheelchairs Quickie Aspire Power...
My display screen is rolling and nothing stops it. My computer says the printer is offline.
Try doing this procedure to correct the problem.
1. Unplug the power cord from the back of the product.
2. Unplug the power cord from any surge protectors or power strips.
3. Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4. Plug the power cord into the back of the product.
5. Plug the power cord into the wall outlet.
6. Press the Power button to turn the product on.
7.Now check if its already working.
May 16, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
The remote module that plug into wall outlet has melted and cord plugged toside will not pull out
1. Put the power off that supply the wall outlet.
2. Cut the cord, and install or put a new rubberized plug
into it, with a rating of at least 20 to 30 amperes.
3. Replace the wall outlet with a rating of 30 amperes.
Then, you can run your heater without any trouble.
Jan 04, 2010 | Heating & Cooling
2000 nissan xterra knock senor and plug 5
Have you changed all the plugs to platinum and wires? My xterra was doing that and I changed all of them and now it runs great. Also, I changed the distribitor cap and rotor button.
Jun 10, 2009 | 2000 Nissan Xterra
Power cords
Yes,
You will constantly draw power from the outlet. Though it may not be as much draw as if you were running a device on it. Try picking up the AC adapter one day when not plugged in to the laptop. It still gets hot.
On another note,
When using AC power you should ALWAYS plug it into the back of the device before plugging it into the wall outlet to avoid excessive power surge.
Apr 17, 2008 | Televison & Video
Xterra Fitness SB4.5r Recumbent Bike Logo
69 people viewed this question
Top Xterra Fitness Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
ray gallant
ray gallant
Are you a Xterra Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
