i have a game saver plus. when i start the seal light comes on then it sucks the door closed then the seal light comes on again and the door opens and it stops
Odds are it is dirty and the vacuum sensor is plugged. That makes it think the vacuum is complete. So it seals. Check the instructions or a youtube and clean it. You need to use the exact cleaning instructions. Odds are that will fix it.
Nov 9, 2008 - I know many of you use vacuum sealers, so hope you might be able to help. I have a FoodSaver Pro Sport, it's probably about three years old.
InstructablesMar 2, 2012 - I have a Food Saver brand Vacuum Sealer, that all of a sudden stopped ... If it won't heat up to seal the bag, then you probably have a break in
wow when I ran my food business I seemed the only one that could get this thing to seal right every night , Im gonna say it was because I wasn't in a big hurry , these machines work great but there not fast it takes sometimes 5/10 minutes to get a good seal on them , and you cant overload them either , when it comes to these less is more , makes for a easier time using them
allow the food to stop about two inches from top edge of bag , and wipe any loose food from the sealing surface (inside) as this will affect the seal as well
Could be the heating element (wire that gets hot enough to melt plastic) is going bad, how long have you been sealing bags with the unit? If you have used it for some time there is the possibility of build up plastic/residue on the the wire or the surface that actually comes in contact with the bag as I would suspect there is a coated surface the element heats up as opposed to the element / wire coming in contact with the plastic itself!
Heating Element / Wire - After heavy use of the vacuum sealer, it is natural for the heating element to break. The amount of seals per sealing wire is dependent on your timer setting, how often you use your vacuum sealer and how thick your vacuum bags are. When you replace the heating element, we usually recommend you replace the sealing strip as well. Different machines have different sizes of heating elements but we carry five stock elements.
