1995 Ford Crown Victoria Logo
P
Paul fox Posted on Apr 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 1995 crown Vic while driving all the trouble lights came on one at a time then the speedo stopped working and all the Gage's started acting strange pulled into driveway and she wouldn't start. Acts like a dead battery but batt. Has full charge. Help!,
syspro
Level 3:
Master:
  • Ford Master 519 Answers
  • Posted on Apr 08, 2014
syspro
Ford Master
Level 3:
Master:
Answers
519
Questions
0
Helped
146205
Points
1751
Have your battery load tested--Carbon Pile Tester--Possible Burnt Strap In Battery
Stop 2006 Ford crown vic fro m beeping
Austin Parker... hello,
When car electronics DECDE to act strangely... it is ALWAYS a good time to check for BATTERY TERMINAL corrosion...
(If you are not comfortable playing with highly corrosive materials... IT'S SERVICE STATION TIME.
So...
You have removed the key... The car is fully in PARK...
BRAKES applied... Lights all turned off... (no lights on dash?).
Repeat your last exit cycle...
Get back in start the car... Make sure everything functions as normal Set your brake... Park, off the lights (everything)...
Put it in gear...
Still beeping... (write down your radio settings)
Time to do a Bill Gates... (hard power cycle)
Disconnect your negative battery lead
and take a 10 minute break...
Reconnect battery... start car & park it again... OK?
ELSE...
If it resumes beeping it will be time to beg, borrow or buy that OBD Reader you always wanted any-way!
HOPE this helps
More Information for DORMAN 85641
What to do when your 1994 crown vic v8 stops in rotation while driving on highway and acting like it was braking on its own?
So many possibilities here... One may be that a wheel bearing is overheating/seizing. Also is the coolent level okay? All fan belts especially to the water pump good? What you need is a good trouble shooting guide because there are just too many possibilities here and too little information. Sorry...
1helpful
All the trouble lights came on one at a time then the amp gage dropped the speedo stopped working and other elec. issues while driving then died in my driveway.
check the drive belt for the alternator for condition and tension. Check battery terminals and posts are shiny clean and tight. have a load test done on the battery to check for dead cell.
2answers
1995 vw jetta speedo and trip gage cutting in and out.
From what you say i think you are correct in saying it is a connection problem, Remove the cluster and check wiring to cluster. make sure pins are good, you may need to bend pins to make them tight when you connect the connector to cluster.
My 90 crown vic won't start. i have fuel to the
I would visually check for spark at the plugs, to make sure spark is getting to the plugs. If spark everywhere, use a gage and check proper fuel pressure and fuel injector pulse.
How long since a tune-up? Any applicable trouble codes?
1988 Ford Crown Vic Strange Idle (Getting Worse)
i am trying to install an aftermarket temperature guage with capillary tube into my 1988 crown victoria ltd 5.0 efi. where does the capillary tube mount?
2helpful
4answers
My 99 Crown Vic acts like it isn't getting gas
check for clogged fuel filter first, usually the pump works or it dosen't, check and get back to me.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
